ComboBox and Modeless Form - Getting error (Object reference not set...)
Hi!
I've seen the post about this topic in the links below:
https://forums.autodesk.com/t5/revit-api-forum/modeless-form-and-combobox/td-p/9119051.
https://forums.autodesk.com/t5/revit-api-forum/how-to-retrieve-modeless-form-s-combobox-s-text-in-ex...
However I couldn't figure it out in my code how to get data into my combobox, getting the same error: "Object reference not set to an instance of an object".
Hope someone can help me...
Command.cs
namespace ElectricalDiagrams
[Transaction(TransactionMode.Manual)]
public class Command : IExternalCommand
public virtual Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
UIApplication uiapp = commandData.Application;
try
App.thisApp.ShowForm(uiapp);
return Result.Succeeded;
catch(Exception ex)
message = ex.Message;
return Result.Failed;
App.cs
public class App : IExternalApplication
internal static App thisApp = new App();
private ModelessForm form;
public Result OnStartup(UIControlledApplication application)
form = null;
thisApp = this;
public Result OnShutdown(UIControlledApplication application)
if (form != null && form.Visible)
form.Close();
public void ShowForm(UIApplication uiapp)
if (form == null || form.IsDisposed)
RequestHandler handler = new RequestHandler();
ExternalEvent exEvent = ExternalEvent.Create(handler);
form = new ModelessForm(exEvent, handler);
form.Show();
public void WakeFormUp()
if (form != null)
form.EnableCommands(true);
RequestHandler.cs
public class RequestHandler : IExternalEventHandler
private Request request = new Request();
public Request Request { get { return request; } }
public string GetName()
return "External Event";
public void Execute(UIApplication uiapp)
try
switch (Request.Take())
case RequestId.None:
return;
case RequestId.GetPanels:
new GetPanels(uiapp, PanelComboBox);
break;
default:
break;
finally
App.thisApp.WakeFormUp();
return;
Request.cs
public enum RequestId : int
None = 0,
GetPanels = 1
private int request = (int)RequestId.None;
public RequestId Take()
return (RequestId)Interlocked.Exchange(ref request, (int)RequestId.None);
public void Make(RequestId requestId)
Interlocked.Exchange(ref request, (int)requestId);
ModelessForm.cs
public partial class ModelessForm : Form
//private Document doc;
private RequestHandler requestHandler;
private ExternalEvent externalEvent;
public ModelessForm(ExternalEvent exEvent, RequestHandler handler)
InitializeComponent();
requestHandler = handler;
externalEvent = exEvent;
protected override void OnFormClosed(FormClosedEventArgs e)
externalEvent.Dispose();
externalEvent = null;
requestHandler = null;
base.OnFormClosed(e);
public void EnableCommands(bool status)
foreach (Control control in this.Controls)
control.Enabled = status;
if (!status)
this.CancelButton.Enabled = true;
private void MakeRequest(RequestId requestId)
requestHandler.Request.Make(requestId);
externalEvent.Raise();
EnableCommands(false);
private void ModelessForm_Load(object sender, EventArgs e)
MakeRequest(RequestId.GetPanels);
private void CancelButton_Click(object sender, EventArgs e)
Close();
GetPanels.cs
namespace ElectricalDiagrams.Extensions
class GetPanels
public GetPanels(UIApplication uiapp, System.Windows.Forms.ComboBox PanelComboBox)
UIDocument uidoc = uiapp.ActiveUIDocument;
Document doc = uidoc.Document;
IList<Element> panelElements = new FilteredElementCollector(doc).
OfCategory(BuiltInCategory.OST_ElectricalEquipment).
WhereElementIsNotElementType().
ToElements();
List<string> panelNames = new List<string>
(panelElements.Select<Element, string>(e => e.Name.ToString()));
try
PanelComboBox.DataSource = panelNames;
catch (Exception ex)
TaskDialog.Show("Error", ex.ToString());
