ComboBox and Modeless Form - Getting error (Object reference not set...)
tiagofrbr
tiagofrbr
Hi!
I've seen the post about this topic in the links below:
https://forums.autodesk.com/t5/revit-api-forum/modeless-form-and-combobox/td-p/9119051.
https://forums.autodesk.com/t5/revit-api-forum/how-to-retrieve-modeless-form-s-combobox-s-text-in-ex...
However I couldn't figure it out in my code how to get data into my combobox, getting the same error: "Object reference not set to an instance of an object".
Hope someone can help me...
Command.cs
namespace ElectricalDiagrams
    [Transaction(TransactionMode.Manual)]
    public class Command : IExternalCommand
        public virtual Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIApplication uiapp = commandData.Application;
            try
                App.thisApp.ShowForm(uiapp);
                return Result.Succeeded;
            catch(Exception ex)
                message = ex.Message;
                return Result.Failed;
App.cs
    public class App : IExternalApplication
        internal static App thisApp = new App();
        private ModelessForm form;
        public Result OnStartup(UIControlledApplication application)
            form = null;
            thisApp = this;
        public Result OnShutdown(UIControlledApplication application)
            if (form != null && form.Visible)
                form.Close();
        public void ShowForm(UIApplication uiapp)
            if (form == null || form.IsDisposed)
                RequestHandler handler = new RequestHandler();
                ExternalEvent exEvent = ExternalEvent.Create(handler);
                form = new ModelessForm(exEvent, handler);
                form.Show();
        public void WakeFormUp()
            if (form != null)
                form.EnableCommands(true);
 RequestHandler.cs
    public class RequestHandler : IExternalEventHandler
        private Request request = new Request();
        public Request Request { get { return request; } }
        public string GetName()
            return "External Event";
        public void Execute(UIApplication uiapp)
            try
                switch (Request.Take())
                    case RequestId.None:
                            return;
                    case RequestId.GetPanels:
                            new GetPanels(uiapp, PanelComboBox);
                            break;
                    default:
                            break;
            finally
                App.thisApp.WakeFormUp();
            return;
Request.cs
    public enum RequestId : int
        None = 0,
        GetPanels = 1
        private int request = (int)RequestId.None;
        public RequestId Take()
            return (RequestId)Interlocked.Exchange(ref request, (int)RequestId.None);
        public void Make(RequestId requestId)
            Interlocked.Exchange(ref request, (int)requestId);
ModelessForm.cs
    public partial class ModelessForm : Form
        //private Document doc;
        private RequestHandler requestHandler;
        private ExternalEvent externalEvent;
        public ModelessForm(ExternalEvent exEvent, RequestHandler handler)
            InitializeComponent();
            requestHandler = handler;
            externalEvent = exEvent;
        protected override void OnFormClosed(FormClosedEventArgs e)
            externalEvent.Dispose();
            externalEvent = null;
            requestHandler = null;
            base.OnFormClosed(e);
        public void EnableCommands(bool status)
            foreach (Control control in this.Controls)
                control.Enabled = status;
            if (!status)
                this.CancelButton.Enabled = true;
        private void MakeRequest(RequestId requestId)
            requestHandler.Request.Make(requestId);
            externalEvent.Raise();
            EnableCommands(false);
        private void ModelessForm_Load(object sender, EventArgs e)
            MakeRequest(RequestId.GetPanels);
        private void CancelButton_Click(object sender, EventArgs e)
            Close();
GetPanels.cs
namespace ElectricalDiagrams.Extensions
    class GetPanels
        public GetPanels(UIApplication uiapp, System.Windows.Forms.ComboBox PanelComboBox)
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Document doc = uidoc.Document;
            IList<Element> panelElements = new FilteredElementCollector(doc).
                OfCategory(BuiltInCategory.OST_ElectricalEquipment).
                WhereElementIsNotElementType().
                ToElements();
            List<string> panelNames = new List<string>
                (panelElements.Select<Element, string>(e => e.Name.ToString()));
            try
                PanelComboBox.DataSource = panelNames;
            catch (Exception ex)
                TaskDialog.Show("Error", ex.ToString());
scgq425
Hi @tiagofrbr :
are you debug this code ? and which row post this error?
this code logic like run the command and collected electraic data to combobox?
LanHui Xu 徐兰辉
Blog
LinkedIn
Revit/CAD Development | Steel Product Manager
tiagofrbr
Yes I did. The row which posts this error is the row 24 from RequestHanlder.cs. The code logic was able to collect the electric data into the combobox, but I found that the issue is that the code at the row 24 from RequestHandler couldn't find the reference for "PanelComboBox", which is the combobox I created in my Modeless Form.
reylorente1
I've been checking your code, I don't master the electrical part of Revit. Add this part to the code, see if it works
    try
                    return;
                var form = Application.OpenForms.OfType<ModelessForm>().FirstOrDefault();
                if (form != null)
                    // Llama a la función para llenar el ComboBox
                    form.Invoke((MethodInvoker)delegate
                        new GetPanels(uiapp, form.PanelComboBox);
                break;
            default:
                    break;
    finally
    return;
scgq425
Hi @tiagofrbr :
i test you code is run ok, i get all electric data and post to combobox . but in you code , i add this paramater to trans PanelCombobox .
and in the link file i push the project you can re-build and debug this .
 public class Value
     public static System.Windows.Forms.ComboBox PanelComboBox;
     Value.PanelComboBox = this.PanelComboBox;
. i push
LanHui Xu 徐兰辉
Blog
LinkedIn
tiagofrbr
Thanks for your help! Here's the solution that I found to be working:
public ModelessForm(ExternalEvent exEvent, RequestHandler handler, UIApplication Uiapp)
    uiapp = Uiapp;
    requestHandler.GetPanelComboBox = PanelComboBox;
    public ComboBox GetPanelComboBox { get; set; }
