Code signing of Revit Addins
harrymattison
Message 1 of 70
harrymattison
Considering the new requirement in 2017 for Revit Addin signing, does anyone have recommendations
  1. Which vendor to use to buy the certificate (presumably someone listed at http://social.technet.microsoft.com/wiki/contents/documents/2592.windows-root-certificate-program-me...
  2. What is the "right" certificate to buy?
For example, how about the "CODE SIGNING CERTIFICATE" for $170/yr (if you buy 3 years)?
Validates and secures your code
Eliminates security warnings during download and installation
Protects with your choice of SHA-1 or SHA-2 encryption
https://www.godaddy.com/web-security/code-signing-certificate
Replies (69)
Message 61 of 70
RichardBinning2010
Hi Neil,
We are experiencing this on our network as well.  It seems to be intermittent, always load works for a while, then all of a sudden, 8 popups 1 for each addin.
Could this be related to updated Revit.ini by chance?
Richard Binning
Director of BIM Technology
Wakefield Beasley & Associates
5200 Avalon Boulevard
Alpharetta, GA 30009
Message 62 of 70
matthew_taylor
One mistake I made recently was that the certificate expired. Perhaps that is why the issue happens 'all of a sudden'?
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Message 63 of 70
rbinning345
No, its still occurring, with no change to certificates.
Could it be related to a Revit.ini update?
Message 64 of 70
rita.aguiar
Hi
Is the only way to automatically load a Revit plugin a Code Signing certificate?
Message 65 of 70
lecartuchen
Neil. Exquisite explanation. Thanks a lot.
BTW, is there an updated official documentation on this matter? Would you please provide a link? Thanks @jeremytammik
Message 66 of 70
jeremytammik
Yes, sure. It is explained in detail in the developer guide:
https://help.autodesk.com/view/RVT/2021/ENU/?guid=Revit_API_Revit_API_Developers_Guide_Introduction_...
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 67 of 70
lecartuchen
Thanks @jeremytammik  and @neil.smithline  for your time. I really appreciate it.
I'm new to this world of code signing certificates. I've been reading a lot but still have two more questions for you guys.
  1. How do I know if the CA I buy a code signing certificate from is a trusted one? I mean what if it is not in your list (Simantec, Digicert, Verisign, Thawte)? These certificates are very expensive for startup developers so I better know before hand if it is a recognized CA or not.
  2. Let's say I bought a certificate. Signed my add-in appropriately and published yeyyy!!!. Within 3~4 months I have a revised improved version of my add-in codewise. Can I re-use the same certificate? If this certificate is valid for 1 or more years, I can't find confirmation that I can re-use it as many times I need. Is that an accurate asumption?
Thanks a lot in advance.
Message 68 of 70
jeremytammik
Thank you for your appreciation.
For your more specific detailed questions on code signing in general, I would suggest researching further in the standard .NET community and asking your vendor, since those questions are not related to the Revit API.
Jeremy Tammik
The Building Coder
Message 69 of 70
boostyourbim
@lecartuchen
Here is some info about how I am signing my dll's and msi files.
https://boostyourbim.wordpress.com/2016/05/04/code-signing-for-revit-2017/
I am able to re-use this certificate as many times as I want.
Message 70 of 70
RevitBuilder43
