Schedule with Revision Clouds
Hi!
Is it possible to make a schedule with Revision Clouds in Revit 2015?
I cant se "Revision Clouds" in the list of categorys, se my picture below.
Best regards Arash
jeremytammik
Dear Arash,
In general, if a feature is not available in the Revit product manually through the user interface, then the Revit API will not provide it either.
Therefore, before thinking about possibly automating any task, it is important to explore the possibilities and develop an optimal solution through the user interface first. For that, I would suggest asking an application engineer, product usage expert, or product support for help on finding a suitable workflow and laying down best practices.
Can you verify that revision clouds can be scheduled manually?
If not, it is almost certainly not possible through the API either.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
