Close All Hidden by API
Dale.Bartlett
Message 1 of 11
Dale.Bartlett
Hi All, I have exhausted the usual sources... Can anyone supply sample code to cause a "Close All Hidden" action? Or how do I call a native Revit command in code? 2011 or 2012. It seems so simple, all help gratefully appreciated. Dale
______________
Yes, I'm Satoshi.
Replies (10)
Message 2 of 11
jeremytammik
Dear Dale,
I am afraid there is no official API solution to access the "Close All Hidden" functionality, and definitely not to call a native Revit command.
All that I can suggest is to explore using the Windows API or porobably better and easier the UI Automation libraries as described in various examples by Rudolf Honke:
http://thebuildingcoder.typepad.com/blog/automation
Completely unsupported and at your own risk!
Best regards,
Jeremy
Jeremy Tammik
Autodesk Developer Network -- http://www.autodesk.com/joinadn
The Building Coder -- http://thebuildingcoder.typepad.com
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 3 of 11
Dale.Bartlett
Hi Jeremy, Thanks for the reply. Pleased I wasn't tooo dumb, but surprised there isn't a function; I'll investigate your suggestions. I guess the API has a way to go to catch up to AutoCAD. My project was to be a "Close to Default View" function to leave Revit projects on the same view. Seemed so simple. I know with 2012 I can set the View. Regards, Dale
______________
Yes, I'm Satoshi.
Message 4 of 11
RevitArkitek
In case anyone is interested, in 2014 there is a Close() method.  I used it like this:
// get open views to close all except the active view
IList<UIView> openViews = uidoc.GetOpenUIViews();
foreach (UIView uiv in openViews)
    if (uiv.ViewId != uidoc.ActiveView.Id)
        uiv.Close();
 It only works on the active document.  I'm not sure if you could close views in other documents by switching the active uidoc/document.
Message 5 of 11
hello, It is not worked in my rvt file with your code. Check my code if there is any problem. pls using System;
using System.Linq; using System.Data;
using System.Collections;
using System.Collections.Generic;
using System.Text;
using System.Windows.Forms;
using Autodesk.Revit;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
namespace command2
[Transaction(TransactionMode.Manual)]
[Regeneration(RegenerationOption.Manual)]
[Journaling(JournalingMode.NoCommandData)]
public class command2 : IExternalCommand
public Autodesk.Revit.UI.Result Execute(ExternalCommandData commandData,
ref string message, Autodesk.Revit.DB.ElementSet elements)
Document doc = commandData.Application.ActiveUIDocument.Document;
UIDocument uidoc = commandData.Application.ActiveUIDocument;
// Selection sel = uidoc.Selection;
uiv.Close();
return Autodesk.Revit.UI.Result.Succeeded;
Message 6 of 11
RevitArkitek
I was merely providing a code snippet, not entire external command. But congrats on achieving that.
Message 7 of 11
pyrosim
Your code works for me.
Does it error out or just not do anything?
If error, can you post the dialog?
Did you register properly in the *.addin file?
Message 8 of 11
RevitArkitek
Sorry, I misread your reply.  I thought you had it working as an external command.
Message 9 of 11
ye,I had it working as an external command .  does it wrong seriously?
Becouse It does nothing when I put this externalcommand to rvt file.
My revit version is 2014 and vs is 2010
And my rvt file is too big, give a email address ,I will send it to you have a look
Thanks for your support!
Message 10 of 11
hi peter,
It does nothing when I put my above externalcommand to rvt file.
I don't know how to check my *.addin file , could you tell me the register method , my revit version is 2014 and vs is 2010
Thanks for your support,let's make it work together!
Message 11 of 11
No need to send the Revit file. You can test your command on any file.
How are you telling Revit to find and run your command? Is it a macro?
