Get the Radius of a Circle (model line)
I want to get the Radius of a circle. I drew this circle by using the model line.
With the following Code I can collect all model line not only the circles but what I want is only the circles and their Radiuses:
Document document = commandData.Application.ActiveUIDocument.Document;
UIDocument uiDocument = new UIDocument(document);
FilteredElementCollector collector = new FilteredElementCollector(uiDocument.Document);
ICollection<Element> collection = collector.OfClass(typeof(CurveElement)).ToElements();
jeremytammik
Dear Habib,
Well, first of all, a curve element is a purely geometrical abstract object and will not appear in the database and therefore never be found or retrieved by the filtered element collector, so OfClass(typeof(CurveElement)) is no use.
You have to search for database objects instead, your model lines (well, they are not lines, actually, are they?), then extract the ones whose curve elements are in fact arcs, and then query each arc for its data.
So maybe this will give you what you need:
.OfClass(typeof(ModelArc));
There is normally no need to use ToElements, since you can iterate over the collector itself straight away.
Best regards,
Jeremy
Jeremy Tammik
Autodesk Developer Network -- http://www.autodesk.com/joinadn
The Building Coder -- http://thebuildingcoder.typepad.com
Jeremy Tammik
Developer Technical Services
The Building Coder
Thank you very much,
I am using now this code. It works good
foreach (Element e in collection)
if (e is ModelArc)
LocationCurve curve = ((LocationCurve)e.Location);
Arc arc = (Arc)curve.Curve;
radius = arc.Radius;
With my best regard
Habib
