Check out the self-paced guide “My First Plug-in”
saikat
Autodesk Autodesk
Message 1 of 82
saikat
Check out the Self-Paced Guide “My First Plug-in” presented by the ADN Revit Team
http://www.autodesk.com/myfirstrevitplugin
Note on 5/11/2018:  My First Plug-in is being migrated to Knowledge Base (similar to this forum). Right now, the marketing URL is not working. In a mean time, you can access here:
https://knowledge.autodesk.com/community/collection/my-first-autodesk-revit-plug
Still work in progress. Working on updating all the links, to the latest three releases, etc.
Are you an Autodesk Revit power user with an interest in becoming even more productive? Would you like to automate or extend the capabilities of Revit, but are new to computer programming? If so, then this guide is designed for you.
“My First Plug-in” is a self-paced tutorial guide for a smooth introduction into the programming world. This is a “one-stop shop” learning path for users who know Autodesk products but are absolutely new to programming and are thinking about taking the plunge. In this guide, you will be working with the Autodesk Revit .NET API and the C# programming language. The supported product version is Autodesk Revit Architecture 2011 and succeeding versions.
There are many resources available on the web for you to learn about the Autodesk Revit API (Application Programming Interface), however, these resources tend to be designed for people who already know programming. This guide is different: it assumes no previous programming knowledge and yet helps you build your first plug-in quickly, without swamping you with details. You’ll have a working application within an hour of starting this material, irrespective of your current level of programming expertise.
The guide will start by reviewing the benefits of customizing Autodesk software before progressing onto lessons covering the use of the Autodesk Revit API. The lessons will start by building a working plug-in before covering more detailed explanations of the underlying principles and further developing the application’s functionality.
Product: Autodesk Revit 2011 or higher
Programming Language: C#
Application Programming Interface (API): Revit .NET API
If you have any feedback on this new guide let us know at [email protected]
Saikat Bhattacharya
Senior Manager - Technology Consulting
Replies (81)
Message 41 of 82
Thanks it help.
I am using Revit2015. it still work with this
Element elem = doc.GetElement(pickedRef);
Message 42 of 82
The Link is dead,
Long live the Link!
Message 43 of 82
mikako_harada
Hi m.touchard,
Which link are you having a problem?  I just tried with this (which is the topic of this post), it works for me now.
Maybe there was a temporary problem with the internet or a server.  Sometimes the browser may have a problem.  I sometimes find refreshing the browser solves a problem.
Mikako Harada
Developer Technical Services
Message 44 of 82
Hey !
After checking again it seems the problem come from Google Chrome which display :
The Page You Requested Was Not Found
The link works very well with Edge even if the redirect URL is the same.
Thanks for the reply!
Message 45 of 82
matthew_taylor
Hi Mikako,
Just to let you know that the link to 'Message Listing' at the base and top of this page incorrectly point to http://forums.autodesk.com/t5/revit-api-forum/bd-p/160/page/11 (in IE11).
Cheers,
Matt
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Message 46 of 82
mikako_harada
Hi Matt,
Just tested with IE11. (Mine says Version: 11.0.9600.17843IS).  Both brings to:
which is correct. Tooltip when you hover on the link also shows the same one.
Maybe it was temporary or somebody else reported and fixed.
Thank you for quickly reporting when you noticed, though.
Mikako Harada
Message 47 of 82
matthew_taylor
Thanks Mikako.
Mine appears absolutely as you say now.
Have a nice weekened.
-Matt
Cheers,
-Matt
Message 48 of 82
I am stuck on adding reference to Visual Studio. Here is the error message after I try to add RevitAPIUI as reference.
I couldn't find any answers. Could anyone help me?
Thanks.
Message 49 of 82
Did you choose the "Class Library (.NET Framework)" when you create your project ?
Besides in the "Build" properties, make sure you have chosen a compatible framework  with Revit (I think the Framework 4.5.2 is ok)
Kind Regards,
GM
Message 50 of 82
Thanks!
I got this problem now.
Message 51 of 82
Message 52 of 82
Hi @Anonymous,
Did you add the following references :
-RevitAPI.dll
-RevitAPIUI.dll
It seems that a reference is missing.
I've tried with these references and it worked for me.
If you still have issues, please provide more information.
Cheers,
GM
Message 53 of 82
Message 54 of 82
Hi @Anonymous
About what I see in your screenshot it seems that it's working : You've put a PickObject in your code whose description is "Please select a group" and I see in the bottom left corner that description"Please select a group". So I assume that your code went through there. I want you to know that the PickObject method don't display a window to the user but only that message in the corner. So for me everything seems good.
Cheers,
GM
Message 55 of 82
Hi @Anonymous
You are right. The plug-in works well. My problem is that the debugging doesn't work well. When I hit start debugging, the toggled line is supposed to turn yellow according to the instruction. But in my situation, it doesn't, which means I could not debug the code line by line.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=20132893
Message 56 of 82
@Anonymous, in the properties of debugging, did you set the configuration to "(Debug) active" ?
If so, I don't know how to fix it sorry...
PS : Sorry the attached picture is in french but I'm sure you will understand it cause it's very similar to English
GM
Message 57 of 82
Hi @Anonymous
I believe this it the problem. Thank you very much.  But the weird thing is that those options are grey out here.
Message 58 of 82
@Anonymous,
Yeah, it seems that it could cause an issue when debugging
I don't know how to fix it especially because you don't have the same version of visual studio I think.
Take a look at this video which explains how to set properly the Visual Studio configuration in order to work with Revit :
https://www.youtube.com/watch?v=C0mNU2bEUSs
When I start with Revit API I've done every project thanks to this video.
GM
Message 59 of 82
@Anonymous
Thank you so much for your help. I appreciate it!
Message 60 of 82
Hi, I'm getting problems when typing the codes of placing a new group in each of the selected rooms. The guide shows two methods and both have errors. I'm using Revit 2017 and Visual Studio 2015.
