Changing ViewReference's refernce view problem
sahin.ikbal
sahin.ikbal
I want to change ViewReference's refernce view, I have found one method "ReferenceableViewUtils.ChangeReferencedView" but its only working for section or callouts and not ViewReference.
Is there any way to do this for this type of element?
Omar_Amen
Hi @sahin.ikbal,
I've checked an instance of reference view via Revit lookup add-in,
I found that the reference view element's meta data is drafted in a built in Revit parameters and not a C# class props!
I didn't try to update the parameter value, may you give it a try ?
I hope it will work,
sahin.ikbal
That's a Read-only parameter.
I have tried.
Ceorl82
Has anybody come up with a solution for reassigning the Target View on a callout?  I'm not getting anywhere with the ReferenceableViewUtils.  Does anyone know which ElementIds I should use in the ChangeReferencedView method?  The explanation in the docs is a little confusing.   I've tried both the Element Id attached to the Target View parameter, as well as, the Id returned from the Target Views AsElementId method.  Both produce the "invalid reference id" error.
As suggestions would be appreciated.
Chuck
