That image doesn't really help. It may be saying the element can't be moved to a deign option because it already exists on one.
For the relevant design Option Set decide what option you want to take forward and set this to Primary (Make Primary). Then go to the top of the branch and select 'Accept Primary...' this will merge the elements on the primary of that option set into the main model and delete the others i.e. removing that option set.
