01:22 PM
I am trying to use this code for duplicate a schedule view and change the filter value.
The code works, the schedule is duplicated, but the value is not changed. I also tried to commit the transaction and restart it before the filter, and regenerate document but not work.
what am I doing wrong?
Dim lst_viewAbaco As List(Of View) = ED_Utility.FiltraAbaco(_doc, "ED-RDET_ABACO")
'Dim viewAbacoID As ElementId = Nothing
Dim viewAbaco As ViewSchedule = Nothing
Dim t1 As New Transaction(_doc, "CopySchedule")
Try
t1.Start()
For Each v As ViewSchedule In lst_viewAbaco
If v.Name.ToUpper = "ED-RDET_ABACO" Then
viewAbaco = TryCast(_doc.GetElement(v.Duplicate(ViewDuplicateOption.Duplicate)), ViewSchedule)
Dim lst_Abaco As List(Of View) = ED_Utility.FiltraAbaco(_doc, "Abaco Armature Partizione" & " - " & str_Part)
If lst_Abaco.Count = 0 Then
If viewAbaco IsNot Nothing Then viewAbaco.ViewName = "Abaco Armature Partizione" & " - " & str_Part
Else
If viewAbaco IsNot Nothing Then viewAbaco.ViewName = "Abaco Armature Partizione" & " - " & str_Part & "_1"
_doc.Regenerate()
Dim filter As ScheduleFilter = viewAbaco.Definition.GetFilter(0)
If filter.IsStringValue Then
filter.SetValue(str_Part)
Next
t1.Commit()
Catch exception1 As Exception
t1.RollBack()
Return 0
End Try
