Change Schedule Filter value
I am trying to use this code for duplicate a schedule view and change the filter value.
The code works, the schedule is duplicated, but the value is not changed. I also tried to commit the transaction and restart it before the filter, and regenerate document but not work.
what am I doing wrong?
 Dim lst_viewAbaco As List(Of View) = ED_Utility.FiltraAbaco(_doc, "ED-RDET_ABACO")
            'Dim viewAbacoID As ElementId = Nothing
            Dim viewAbaco As ViewSchedule = Nothing
            Dim t1 As New Transaction(_doc, "CopySchedule")
            Try
                t1.Start()
                For Each v As ViewSchedule In lst_viewAbaco
                    If v.Name.ToUpper = "ED-RDET_ABACO" Then
                        viewAbaco = TryCast(_doc.GetElement(v.Duplicate(ViewDuplicateOption.Duplicate)), ViewSchedule)
                        Dim lst_Abaco As List(Of View) = ED_Utility.FiltraAbaco(_doc, "Abaco Armature Partizione" & " - " & str_Part)
                        If lst_Abaco.Count = 0 Then
                            If viewAbaco IsNot Nothing Then viewAbaco.ViewName = "Abaco Armature Partizione" & " - " & str_Part
                        Else
                            If viewAbaco IsNot Nothing Then viewAbaco.ViewName = "Abaco Armature Partizione" & " - " & str_Part & "_1"
                        End If
                        _doc.Regenerate()
                        Dim filter As ScheduleFilter = viewAbaco.Definition.GetFilter(0)
                        If filter.IsStringValue Then
                            filter.SetValue(str_Part)
                        End If
                    End If
                Next
                t1.Commit()
            Catch exception1 As Exception
                t1.RollBack()
                Return 0
            End Try
JimJia
Dear scarta,
Please call "SetFilter" function after setvalue.
                            viewAbaco.Definition.SetFilter(0,filter)
                        End If
It seems you need to replace the old filter, so that it can work.
Please have a try.
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
Thanks!!!
now work correctly!!
Stefano
FrankHolidaytoiling
Thanx for the solution also worked for me.
