ReferenceIntersector.FindNearest does not intersect with Curtain Walls
Message 1 of 9
When I use ReferenceIntersector.FindNearest, it will find a wall, but it doesn't find a curtain wall.
My code is:
var view3d = RUtils.Get3dView(doc);
ReferenceIntersector refIntersector = new ReferenceIntersector(
        new ElementCategoryFilter(BuiltInCategory.OST_Walls),
        FindReferenceTarget.Element,
        view3d
var x = refIntersector.FindNearest(stairBase, baseDirection);
and after executing this, the `x` is `null`.
I know the base point and direction are fine because when I change the type of wall in the UI to be, say "Interior - Partition" instead of "SH_Curtain wall" and rerun the code, then it does find it.  I expect it to intersect the curtain wall also since using the Revit Lookup tool, the curtain wall has BuiltinCategory of "OST_Walls" (just like the partition wall).
BTW, the function for getting the 3d view is:
        public static View3D Get3dView(Document doc, bool createIfNull=true)
            FilteredElementCollector collector = new FilteredElementCollector(doc).OfClass(typeof(View3D));
            foreach (var elem in collector) {
                var view = (View3D) elem;
                if (view.IsTemplate || view.IsPerspective) {
                    continue;
                if (view.IsSectionBoxActive) {
                    var trans = new Transaction(doc);
                    trans.Start("disable section box");
                    view.IsSectionBoxActive = false;
                    doc.Regenerate();
                    trans.Commit();
                    return view;
            return createIfNull ? create3dView(doc) : null;
How can I have it intersect the curtain wall also?
Replies (8)
Message 2 of 9
RPTHOMAS108
Reference intersector will only work if item is visible in view you use. So you should not be picking at random because view discipline, manual hide, category hide etc. all affect what is visible in an existing view.
Either create a new view with what you are aiming at visible or use one which you know the visibility settings of. The issue may be something else but it is usually this.
Message 3 of 9
Thanks @RPTHOMAS108, that's good to know about creating a new 3D view.  I will keep that in mind.
In this case, that appears not to be the issue.  I replaced my call to get the 3D view to be:
var view3d = RUtils.create3dView(doc);
and that function looks like:
public static View3D create3dView(Document doc) {
    ViewFamilyType vft = new FilteredElementCollector(doc)
            .OfClass(typeof(ViewFamilyType))
            .Cast<ViewFamilyType>()
            .FirstOrDefault(x => ViewFamily.ThreeDimensional == x.ViewFamily);
    using (var trans = new Transaction(doc)) {
        trans.Start("Create 3D View");
        var view3D = View3D.CreateIsometric(doc, vft.Id);
        trans.Commit();
        return view3D;
But it still does not find the curtain wall.  I've also confirmed the curtain wall is
I've drawn a model line for debugging purposes to show the line from the intersection (or no line if no intersection is found).  If I keep the wall as "Interior - Partition", then it intersects it (see attachment).  If curtain wall, it does not intersect...
Any other ideas?
Message 4 of 9
In case it's helpful, here's another example of the result. Notice it goes straight through the curtain wall, but stops at the wall.  This is the sample project that ships with Revit 2018.
Message 5 of 9
so-chong
hi, try to replace:
with:
ReferenceWithContext x = refIntersector.FindNearest(stairBase, baseDirection);
FindNearest Method:
http://www.revitapidocs.com/2017.1/866e1f2b-c79a-4d9f-1db1-9e386dd42941.htm
i'm not sure if this helps, is this a code snippet?
it will help to post your code completely where things might go wrong.
Message 6 of 9
RPTHOMAS108
Perhaps you need to use a logical or filter for the component categories of the curtain wall element i.e.
OST_CurtainWallPanels
OST_CurtainWallMullions
OST_Walls (Also include normal wall category for other non curtain walls)
etc.
When you select the wall it highlights the wall container which then has visible geometry reported to the lookup tool. Ordinarily geometry is invisible, so there is no geometry to find in the OST_Walls element. This is my theory.
Message 7 of 9
Awesome, including `OST_CurtainWallPanels` and `OST_CurtainWallMullions` indeed solved it.  Thanks!
I'm wondering how, in the future, I'll be able to know the relevant component categories, so I can answer my own question next time.  I think I can do it with Loadable Families since I can edit the family and see its different components, but for a system family like walls I don't know how to do that.  Is there a way to see the component categories?  Somewhere in the Revit Lookup tool perhaps?
@so-chong, thanks for your answer also.  I don't think that was the issue.  Since FindNearest already returns a ReferenceWithContext object, I reckon leaving it as `var` is equivalent to explicitly declaring the type.
Message 8 of 9
RPTHOMAS108
Yes, you can select the subcomponent by hovering over with the mouse and then pressing tab repeatedly to cycle through items.
Lookup tool then lists the category as below.
Can also extract the values and names from the BuiltInCategory enum and look for likely items there.
Message 9 of 9
Awesome, thanks!
