Change Project Units
ChristianMolino
ChristianMolino
I am working on an add-in that will export a SAT file, but using the standard project unit of foot and fractional inches is causing the sat files to export at 1/12 scale. I found that changing the global units to fractional inches exports the SAT file at the correct scale.
To accomplish this via the API, I am trying to save the original units, change them to fractional inches, do the exports and then change the units back to the original. I am getting really hung up with the ForgeTypeId's and cannot get the code to run. What am I doing wrong? I am extremely new to coding/the Revit API so explain it to me like I am 5 please lol!
public void ExportSATFiles(Document doc, View3D view, ElementId dualDeckId)
// Retrieve the project's current unit settings for length
FormatOptions originalFormatOptions = doc.GetUnits().GetFormatOptions(SpecTypeId.Length);
Units originalUnits = doc.GetUnits();
try
// Change the project units to fractional inches
Units tempUnits = new Units(UnitSystem.Imperial);
FormatOptions inchFormatOptions = new FormatOptions(new ForgeTypeId("autodesk.spec.aec:length.unit#fractionalInches"));
tempUnits.SetFormatOptions(SpecTypeId.Length, inchFormatOptions);
using (Transaction tx = new Transaction(doc, "Set Project Units to Fractional Inches"))
tx.Start();
doc.SetUnits(tempUnits);
tx.Commit();
// Now perform the SAT export with units set to fractional inches
PerformSATExport(doc, view, dualDeckId);
// Restore the original units
using (Transaction tx = new Transaction(doc, "Restore Original Project Units"))
tx.Start();
doc.SetUnits(originalUnits);
tx.Commit();
catch (Exception ex)
MessageBox.Show("Error during SAT export: " + ex.Message);
// Ensure the units are set back to original even if an error occurs
tx.Start();
tx.Commit();
Speed_CAD
Hi Christian,
What is the error message? So that someone can help you better, it is important that you provide more information.
Mauricio Jorquera
Mohamed_Arshad
Hi @ChristianMolino
     You have given the wrong ForgeTypeId in FormatOptions , I have modified your code a little bit, Kindly refer to the below code for additional reference.
Reference Code:
		try
			FormatOptions inchFormatOptions = new FormatOptions(UnitTypeId.FractionalInches); ///Code Modified
				tx.Start();
				tx.Commit();
			//Restore the original units
				tx.Start();
				tx.Commit();
				tx.Start();
				tx.Commit();
You don't want to pass string in the constructor, can directly use its UnitTypeId Class static properties like below code
I have attached few links based on the ForeTypeId, Kindly take a look of those.
https://thebuildingcoder.typepad.com/files/revit_platform_api_changes_and_additions_2022.pdf
https://thebuildingcoder.typepad.com/blog/2021/06/forgetypeid-and-units-revisited.html#5
https://forums.autodesk.com/t5/revit-api-forum/forgetypeid-how-to-use/td-p/9439210
Hope this will Helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
ChristianMolino
Awesome, this worked. Thank you!
