Change Phase of Revit Link in View Template
ggetts5RNN9
ggetts5RNN9
I am trying to automate changing the phase of a Revit Link inside of a View Template.
Here is what happens when I create a new view using the Revit user interface. This same issue happens when I use the Revit API to automatically create the views in a project setup script.
- The new view from my model shows the New Construction phase (pic 1).
- However, the architectural model Revit Link has it set to a different phase, even when it is marked as "By Host View" (pic 2).
This means I have to change all my view templates to "Custom" for each Revit Link and manually set the right phase for each.
I have been able to use the following code to successfully change the Phase Filter in the Revit Link Display Setting, but have not been able to change the Phase. It seems this may not be exposed in the Revit API.
Are there any ideas why this may not be working?
using (Transaction tx = new Transaction(doc, "Set Revit Link Phase in View Template"))
    tx.Start();
    try
        // Find the view template by name
        ViewPlan viewPlan = doc.ActiveView as ViewPlan;
        ElementId viewTemplateId = viewPlan.ViewTemplateId;
        Autodesk.Revit.DB.View viewTemplate = doc.GetElement(viewTemplateId) as Autodesk.Revit.DB.View;
        if (viewTemplate != null)
            //System.Windows.MessageBox.Show("viewTemplate not null");
            if (viewTemplate.IsTemplate)
                //System.Windows.MessageBox.Show("ViewTemplate is template");
            else
                System.Windows.MessageBox.Show("View template is not a template");
                return Result.Failed;
        else
            System.Windows.MessageBox.Show("View template not found");
        // Find the Revit Link instance by name or other criteria
        FilteredElementCollector linkCollector = new FilteredElementCollector(doc);
        RevitLinkInstance linkInstance = linkCollector.OfClass(typeof(RevitLinkInstance))
            .Cast<RevitLinkInstance>()
            .FirstOrDefault(); // Modify to filter by specific link name if needed
        if (linkInstance == null)
            System.Windows.MessageBox.Show("Error", "No Revit Link instance found.");
        // Find the desired phase by name
        Autodesk.Revit.DB.Phase targetPhase = new FilteredElementCollector(doc)
            .OfClass(typeof(Autodesk.Revit.DB.Phase))
            .Cast<Autodesk.Revit.DB.Phase>()
            .FirstOrDefault(p => p.Name == "Phase 1A"); // Replace with desired phase name
        if (targetPhase == null)
            System.Windows.MessageBox.Show("Phase 'Phase 1A' not found.");
        // Set the PhaseId of the Revit Link instance
        Autodesk.Revit.DB.Document linkDoc = linkInstance.GetLinkDocument();
        System.Windows.MessageBox.Show(linkDoc.Title);
        Parameter phaseCreatedParameter = linkInstance.get_Parameter(BuiltInParameter.PHASE_CREATED);
        System.Windows.MessageBox.Show(phaseCreatedParameter.Definition.Name + " - " + phaseCreatedParameter.AsElementId());
        Autodesk.Revit.DB.Element phaseCreated = linkDoc.GetElement(phaseCreatedParameter.AsElementId());
        if (phaseCreated != null)
            System.Windows.MessageBox.Show(phaseCreated.ToString() + " - " + targetPhase.ToString());
        else
            System.Windows.MessageBox.Show("phaseCreated is null - " + targetPhase.ToString());
        linkInstance.get_Parameter(BuiltInParameter.PHASE_CREATED).Set(targetPhase.Id);
        // Ensure the view template's phase filter allows the link to display
        PhaseFilter phaseFilter = new FilteredElementCollector(doc)
            .OfClass(typeof(PhaseFilter))
            .Cast<PhaseFilter>()
            .FirstOrDefault(pf => pf.Name == "Show All"); // Use appropriate phase filter
        if (phaseFilter != null)
            viewTemplate.get_Parameter(BuiltInParameter.VIEW_PHASE_FILTER).Set(phaseFilter.Id);
        // Reset Revit Link overrides in the view template to use "By Host View"
        Category linkCategory = doc.Settings.Categories.get_Item(BuiltInCategory.OST_RvtLinks);
        if (linkCategory != null)
            OverrideGraphicSettings overrides = new OverrideGraphicSettings();
            viewTemplate.SetCategoryOverrides(linkCategory.Id, overrides); // Reset to default
        // Attempt to reset link-specific overrides (workaround for phase mapping)
        OverrideGraphicSettings linkOverrides = new OverrideGraphicSettings();
        viewTemplate.SetElementOverrides(linkInstance.Id, linkOverrides); // Reset link-specific overrides
        //// Diagnostic: Verify settings
        //string diagMessage = $"View Template: {viewTemplate.Name}\n" +
        //                    $"Phase: {doc.GetElement(viewTemplate.get_Parameter(BuiltInParameter.VIEW_PHASE).AsElementId()).Name}\n" +
        //                    $"Phase Filter: {doc.GetElement(viewTemplate.get_Parameter(BuiltInParameter.VIEW_PHASE_FILTER).AsElementId()).Name}\n" +
        //                    $"Revit Link: {linkInstance.Name}\n" +
        //                    $"Link Phase (Created): {doc.GetElement(linkInstance.get_Parameter(BuiltInParameter.PHASE_CREATED).AsElementId()).Name}";
        //Autodesk.Revit.UI.TaskDialog.Show("Diagnostics", diagMessage);
    catch (Exception ex)
        System.Windows.MessageBox.Show($"Failed to set Revit Link phase: {ex.Message} \n {ex.StackTrace}");
    tx.Commit();
ggetts5RNN9
Doing further investigation, having Revit Links checked or unchecked in the View Template makes a difference. If Revit Links is checked in the View Template, it always has the Linked Model go to the most recent phase when creating a new view. The behavior below happens when creating a view through the user interface or through the API.
Is anyone else not seeing this behavior?
Pic 1: Phase Mapping
Pic 2: Our model view phase
Pic 3: Linked Model view phase if Revit Links is unchecked in the view template
Pic 4: Linked Model view phase if Revit Links is checked
