How do I OOP in Revit API?
XARMA
XARMA
I make a simple test add-in.
It just appear a window that is made by xaml file.
And I have wanted to add some function(Picking Object and window get element ID and appear  that).
I can make some code in Command Class but, I want to learn about using other class.
so I added another class for Picking Object, But How do I write the codes?
Have I to use IExternalCommand or Result Execute? and Where can I get more information about something like that?
jeremy_tammik
To learn OOP, you need to read some basic introductions to the topic. The Revit API is not the best place to start, I'm afraid. Here are some suggestions by Gemini:
XARMA
Thank you for your advice
