Change Duct Element paramater, "System Type" from "Undefined" to "Supply Air"
MehtaRajesh
MehtaRajesh
In Revit MEP
We are trying to update Duct Element paramater, "System Type" from "Undefined" to "Supply Air" programatically.
The code is written as below
;;Duct Selection
UIApplication app = commandData.Application;
Document doc = app.ActiveUIDocument.Document;
Selection sel = app.ActiveUIDocument.Selection;
Reference ref1 = sel.PickObject(ObjectType.Element, "please pick a duct");
Duct objDuct = doc.GetElement(ref1) as Duct;
;; Filter
List<ElementId> DuctSystemTypelst = new FilteredElementCollector(doc).OfCategory
(BuiltInCategory.OST_DuctSystem).ToElementIds().ToList();
;;Getting the parameter value of System Type
Parameter systy = objDuct.get_Parameter(BuiltInParameter.RBS_DUCT_SYSTEM_TYPE_PARAM);
;;Setting the Parameter value of "System type"  to "Supply Air", as "Supply Air" is at second position of DuctSystemTypelst
systy.Set(DuctSystemTypelst[1]);    (RETURNING TRUE)
Afterwards when we check value of "System type" parameter of selected duct using
systy.asElementid();
Returning {-1}  means Undefined
Please help to solve the issue
Thanks in advance for your kind support in this regards
jeremytammik
Dear Mehta Rajesh,
Thank you for your query.
You are retrieving the list of duct system types in DuctSystemTypelst and using [1] to access the second entry in the list.
You are not checking how many entries it contains, nor what the value of the second entry happens to be.
Is that intentional?
Maybe the second value is exactly ElementId.Undefined, e.g., -1.
How about assigning it to an intermediate value and having a look in the debugger, e.g.,
  ElementId systemTypeId = DuctSystemTypelst[1];
Maybe you actually want
  ElementId systemTypeId = DuctSystemTypelst[0];
Here is a Chinese article on editing ducts that may be of interest to you:
http://www.cnblogs.com/zhangchen-87/articles/2385250.html
Google translate will happily translate it for you.
It includes a snippet of code showing how to set the value of the RBS_DUCT_SYSTEM_TYPE_PARAM built-in parameter.
You may also be interested in taking a look at the AdnRme sample, which show lots of other interesting duct related stuff:
https://github.com/jeremytammik/AdnRme
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
MehtaRajesh
Hi Jeremy,
Thanks for your quick reply.
There are three duct system types  "Exhaust Air", "Return Air" and "Supply Air" hence ElementId.Undefined is not be the case.
Whille Debugging also we are getting  the required duct system type in DuctSystemTypelst list at second element DuctSystemTypelst(1)
Rajesh
