Section Marker Rotation Angle
Dale.Bartlett
Dale.Bartlett
Am I correct in the assumption that Section and Elevation Markers do not have a Rotation Angle property? My research is showing that I can calculate and set the Section Box, and this achieves the desired result. Is this correct?
http://thebuildingcoder.typepad.com/blog/2012/06/create-section-view-parallel-to-wall.html
______________
Yes, I'm Satoshi.
jeremytammik
Dear Dale,
Thank you for your query.
I'm checking with the development team...
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
jeremytammik
Dear Dale,
Thank you for your patience.
The development team reply:
I don't think there's a Rotation Angle property.
The mapping of Section Box properties to how the view is set up is described pretty well in the remarks for ViewSection.Create():
Create a section whose view volume corresponds geometrically with the specified sectionBox. The view direction of the resulting section will be sectionBox.Transform.BasisZ and the up direction will be sectionBox.Transform.BasisY. The right hand direction will be computed so that (right, up, view direction) form a left handed coordinate system. The resulting view will be cropped, and far clipping will be active. The crop region will correspond to the projections of BoundingBoxXYZ.Min and BoundingBoxXYZ.Max onto the view's cut plane. The far clip distance will be equal to the difference of the z-coordinates of BoundingBoxXYZ.Min and BoundingBoxXYZ.Max.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
Dale.Bartlett
Thanks Jeremy. I'll translate all that to: "the Section Box defines the angle" and guess the same applies to Elevation Markers. Much appreciated.
______________
Yes, I'm Satoshi.
jeremytammik
Dear Dale,
Thank you for your appreciation.
My pleasure entirely.
Have fun 🙂
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
