Category.Name
Category.Name
sonicer
Category.Name
sonicer
I am preparing add-in and using pick object filter element.
I found this code on help webpage
public bool AllowElement(Element element)
        if (element.Category.Name == "Mass")
            return true;
        return false;
But it does't work if you have Revit in other language.
it's not universal code for all developers.
my code is longer and used BuiltInCategory parameter
Category cat = doc.GetElement(e).Category;
bcat = (BuiltInCategory)cat.Id.IntegerValue;
BIM.Frankliang
Dear Friend,
I usually use below method to avoid using name comparision
elem.Category.Id.IntegerValue == (int)(BuiltInCategory.XXX)
Best Regards
Frank Liang
jeremytammik
Thank you both for your good advice!
I fully agree.
I always recommend to avoid using language dependent comparisons, both for language independence and (less importantly)  efficiency reasons.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
