cannot retrieve omniclass number
pmeigneux
pmeigneux
cannot retrieve omniclass number (Revit 2017).
My Code :
public RenderNodeAction OnElementBegin(ElementId elementId)
    Element El = _StackDoc.Peek().GetElement(elementId);
    BuiltInParameter _bipCode = BuiltInParameter.OMNICLASS_CODE;
    BuiltInParameter _bipDesc = BuiltInParameter.OMNICLASS_DESCRIPTION;
    String CatS = "Show Standard parameters in selected " + CTCT + ":\n";
    foreach (Parameter para in El.Parameters)
        string defName = para.Definition.Name + " = ";
        // Use different method to get parameter data according to the storage type
        switch (para.StorageType)
            case StorageType.Double:
                //covert the number into Metric
                defName += para.AsValueString();
                Double Test = para.AsDouble() * 25.4;
                String TESTS = Test.ToString();
                break;
            case StorageType.ElementId:
                //find out the name of the element
                ElementId id = para.AsElementId();
                if (id.IntegerValue >= 0)
                     defName += _StackDoc.Peek().GetElement(id).Name;
                else
                     defName += id.IntegerValue.ToString();
                break;
            case StorageType.Integer:
                if (ParameterType.YesNo == para.Definition.ParameterType)
                     if (para.AsInteger() == 0)
                          defName += "False";
                     else
                          defName += "True";
                else
                     defName += para.AsInteger().ToString();
                break;
            case StorageType.String:
                defName += para.AsString();
                break;
            default:
                defName = "Unexposed parameter.";
                break;
        CatS = CatS + defName + "\n";
    String OmiClass = "";
    if (El.get_Parameter(_bipCode) != null)
         OmiClass = "<" + El.get_Parameter(_bipCode).AsString() + ">";
    else
         OmiClass = "<>";
    if (El.get_Parameter(_bipDesc) != null)
         OmiClass = OmiClass + "<" + El.get_Parameter(_bipDesc).AsString() + ">";
    else
         OmiClass = OmiClass + "<>";
    TaskDialog.Show("Debug", CatS + "\n\n OmiClass = " + OmiClass);
    return RenderNodeAction.Proceed;
My Rvt Model and Result on Windowns (in attachment).
Philippe.
matthew_taylor
Hi @pmeigneux,
Have you used RevitLookup to check whether you are looking in the same place?
e.g. Not on an element, but on a familysymbol etc.
Everything will become clear.
Cheers,
-Matt
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
pmeigneux
Hi Matt,
Please send me more detail.
Philippe.
matthew_taylor
@pmeigneux
RevitLookup can be found here: https://github.com/jeremytammik/RevitLookup
It allows you to browse selected elements, the document database etc.
Once you have it installed, you would select the door > Revit Lookup > Snoop Current Selection > Family Symbol (in right-hand pane) > Parameter Set (in right-hand pane), OmniClass Number (in left-hand pane), the values will then be shown in the right-hand pane.
A lo-fi method using the actual Revit UI can be seen in the attached image.
RevitLookup is an indispensable tool for browsing Revit. Install it as a top priority.
Cheers,
-Matt
Cheers,
-Matt
pmeigneux
Thank you Matt.
How from the element having access to his family and the parameters of this one?
Philippe.
matthew_taylor
Hi @pmeigneux
Something like this:
dim famInstance as FamilyInstance =trycast (elem,familyinstance)
Dim famSymbol as familysymbol = famInstance.symbol
then get the parameter from the famSymbol object.
All of this will all become very apparent when you use RevitLookup. I cannot stress enough that you should install it and use it regularly to see the association between objects etc.
Cheers,
-Matt
Cheers,
-Matt
pmeigneux
Thank you Matt
