Get Ribbon Button Click Event in API
Message 1 of 13
I need to find the ribbon button click event in revit API. Kindly help me to accomplish this.
Thanks and Regards,
Vinoth Kumar.R
Replies (12)
Message 2 of 13
matthew_taylor
Hi @Anonymous,
This previous post should give you what you need:
http://forums.autodesk.com/t5/revit-api-forum/recording-executed-commands/m-p/6675159/highlight/true#M19334
Cheers,
-Matt
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Message 3 of 13
Hi Matt,
Thanks for the reply. I have not found the event "ItemExecuted" which was mentioned in that link for RibbonItem or RibbonButton classes which was available in Autodesk.Windows dll. Whatever we are adding to existing panels for those items we can get the click event. But for the items which are available default in Revit for those i am not able to find the click event.
Thanks and Regards,
Vinoth Kumar.R
Message 4 of 13
matthew_taylor
Hi Vinoth,
Here's a snippet to get you started. I actually use the UIElementActivated event:
Imports Autodesk.Revit.Attributes
Imports adWin = Autodesk.Windows
<Transaction(TransactionMode.Manual)> _
<Regeneration(RegenerationOption.Manual)> _
<Journaling(JournalingMode.UsingCommandData)> _
<DisplayName("Application Name")> _
<Description("Application Description")> _
Public Class YourApp
    Implements UI.IExternalApplication
  Public Function OnStartup(ByVal a As UI.UIControlledApplication) As UI.Result Implements UI.IExternalApplication.OnStartup
                  'event handler
            AddHandler adWin.ComponentManager.UIElementActivated, AddressOf ComponentManager_UIElementActivated
      Return UI.Result.Succeeded
  End Function
  Public Function OnShutdown(ByVal a As UI.UIControlledApplication) As UI.Result Implements UI.IExternalApplication.OnShutdown
                  RemoveHandler adWin.ComponentManager.UIElementActivated, AddressOf ComponentManager_UIElementActivated
  End Function
  Private Sub ComponentManager_UIElementActivated(ByVal sender As Object, ByVal e As Autodesk.Windows.UIElementActivatedEventArgs)
         'do your thing with the e
  end sub
end class
Let us know how you get on.
Cheers,
-Matt
Cheers,
-Matt
Message 5 of 13
Hi Matt,
The code you have provided does not work. Thanks for the reply.
Thanks and Regards,
Vinoth Kumar.R
Message 6 of 13
matthew_taylor
Hi @Anonymous,
'Does not work'? You're going to have to explain better than that!
I can assure you that it does work. I use it myself.
Explore the e object in the ComponentManager_UIElementActivated function.
Put a break mark in there and browse the objects.
Cheers,
-Matt
Cheers,
-Matt
Message 7 of 13
Hi Matt,
The code you have provided which will work only for the items you are going to add to the RibbonPanels into Revit. But the query was different. I have to get the click events for the items which are available in Revit by Default. Please refer the attached image.
Thanks and Regards,
Vinoth Kumar.R
Message 8 of 13
matthew_taylor
@Anonymous,
You are wrong. I use it to trap all ribbon item clicks.
Such as this:
Modify > Modify > Delete (Modify tab, Modify Panel, Delete item)
You will need to investigate further.
Cheers,
-Matt
Cheers,
-Matt
Message 9 of 13
Hi Matt,
Apologies. Your are not wrong.
Thanks and Regards,
Vinoth Kumar.R
Message 10 of 13
TheRealChrisHildebran
Matt (@matthew_taylor) , thank you for your example on monitoring UI Click Events!
There is a button id like to monitor which does not trigger the event. It is the Settings button in the MEP Fabrication Parts Dockable Dialog (Screenshot below). Have you found this to be true also? Ive examined the e object and looked at other members of  'Autodesk.Windows' but nothing pops out to me.
Any thoughts?
Message 11 of 13
matthew_taylor
Hello @TheRealChrisHildebran ,
This method will not work for what you are trying to do.
I would suggest exploring the posts under this category:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.32
Regardless, I would suggest you don't even need to do this using dialogs. Check out the FabricationConfuguration object. Not something I've had dealings with, but it may have what you need. https://www.revitapidocs.com/2020/119c73a2-a113-aa8c-e032-e80d22e31ac8.htm
Regardless of your decided method, I suggest that any issues you come up against should be in their own forum post. That way you'll have multiple people looking at it.
Cheers,
-Matt
Message 12 of 13
Thanks for the feedback Matt!
I definitely do look at Jeremy's gold mine and refer to the Revit API docs daily and incidentally. They are both tabs that open immediately upon opening my browser. 😁 In this case there is no event in the Revit API Class you linked to.
Normally i would have opened a new post but i think my question just extended the original post a bit keeping them connected.
Simply wanted to see if you had any experience with your solution to the OP working on non-Ribbon items.
Message 13 of 13
matthew_taylor
Ah, I have seen your other post which spells out your purpose. I'll reply there.
Cheers,
-Matt
