Cannot print on Ricoh wide format mpwc2201 printer using Postscript driver
03:47 AM
Dear Support,
I am using a Autodesk revit 2018 version 18.3.2.7 to print revit file and there is missing drawing data . Printout is incomplete and a message shows "require more memory than in available in this printer" printed on 2nd page. The printer only use Postscript driver and there is no PCL driver available. the revit file which is 200Mb larger above will occur this issue. The ricoh wide format printer itself has 4GB in built memory. Does postscript driver does not support large file print due to memory not allocate properly? I had tried to set "Optimize for Portability" at device option at printer driver side still no improvement. Please advice
Guy
