SPLITING BEAMS AT COLUMN INTERSECTION
AGYEMANG.OFOSU
Message 1 of 1
AGYEMANG.OFOSU
The code works till the second split which the elementID is not recognized. The Idea is to get all beams in a model and split at column intersection to identify each beam with MARK. Tried to use a transaction method Arnobel
using(TransactionGroup transgroup = new TransactionGroup(doc,"split"))
	using(Transaction trans = new Transaction(doc))
		try
			transgroup.Start();
			trans.Start("First");
			splittedElementId= eleinstance.Split(pa);
			Element splittedelement= doc.GetElement(splittedElementId);
			doc.Regenerate();
			joinedcolumnstosplitbeams=JoinedElementUtils.GetJoinedColumns(doc,splittedelement);
			if (trans.Commit() != TransactionStatus.Committed)
				TaskDialog.Show("Fail", Result.Failed.ToString());
			trans.Start("Second");
			if (joinedcolumnstosplitbeams.Count>2 )
				foreach (var coll in joinedcolumns)
					if(JoinedElementUtils.IsColumnJoinedToBeamEnds(doc,splittedelement,coll)==false)
						Curve newmaincurve = geo.GetElementCurve(splittedelement);
						Solid newcosolid = geo.GetSolid(coll);
						Curve newinterse = geo.GetIntersectedCurve(newmaincurve,newcosolid);
						FamilyInstance splitinstance = (FamilyInstance)splittedelement;
						double paranorm= geo.GetNormalizedParameterColumnBeamIntersection(newmaincurve,newinterse);
						splitinstance.Split(paranorm);
						trans.Commit();
				TaskDialog.Show("Failed", Result.Failed.ToString());
			transgroup.Assimilate();
		catch
			TaskDialog.Show("Failing", Result.Failed.ToString());
	TaskDialog.Show("Success", Result.Succeeded.ToString());
Replies (0)
