Cannot print on Ricoh wide format mpwc2201 printer using Postscript driver
Dear Support,
   I am using a Autodesk revit 2018 version 18.3.2.7 to print revit file and there is missing drawing data . Printout is incomplete and a message shows "require more memory than in available in this printer" printed on 2nd page. The printer only use  Postscript driver and there is no PCL driver available. the revit file which is 200Mb larger above will occur this issue. The ricoh wide format printer itself has 4GB in built memory. Does postscript driver does not support large file print due to memory not allocate properly? I had tried to set "Optimize for Portability" at device option at printer driver side still no improvement. Please advice
Guy
jeremytammik
Dear Guy,
This is not support, and unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
