Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Can't see files in the cloud and can't update
1 REPLY 1
ravit.gal7A95D
99 Views, 1 Reply
I work with cloud model, I can my model at the web, but in Revit, using the Autodesk docs location, the folder is empty.
I try updating the Revit, but the update keep failing - error 3051.
I checked with the bim manager and i have all the permissions..
1 REPLY 1
This discussion forum is dedicated to programming Revit using the Revit API.
Afaict from your description, you are not doing anything programmatically yourself using the Revit API, just using the standard Revit user interface.
I am afraid you cannot expect an answer to a question like yours relating to product setup, optimisation, usage, or other end-user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are better equipped to address this topic than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Forma Design Contest
Rail Community
