Can't place a group
Can't place a group
a.sabatier
Can't place a group
a.sabatier
Hi
I don't know where is my mistake but when I try to create an instance of a group nothing happens..
            // On crée la liste de tous les groupes présents dans le fichier
            List<GroupType> collectiongrouptype = new FilteredElementCollector(doc).
                OfClass(typeof(GroupType)).OfType<GroupType>().ToList();
                using (ConfigurateurBVForm f = new ConfigurateurBVForm())
                    #region  Bouton Appliquer
                    f.applyButton.Click += (sender, e) =>
                        using (Transaction tr = new Transaction(doc))
                            tr.Start("Insert group");
                            //On regarde le nom qui est à inserer
                            foreach (GroupType grouptype in collectiongrouptype)
                                TaskDialog.Show("e", grouptype.Name);
                                if (grouptype.Name == "montype")
                                    TaskDialog.Show("ee", "if condition");
                                    //On crée l'instance.
                                    try
                                        XYZ zero = new XYZ(0, 0, 0);
                                        doc.Create.PlaceGroup(zero, grouptype);
                                        break;
                                    catch { }
                                    tr.Commit();
                    f.ShowDialog();
                #endregion
            return Result.Succeeded;
Thanks for your help
Alexandre
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @a.sabatier ,
Filter Group instead of Grouptype and from the filtered group try to get the GroupType.
IList<Element> groups = new FilteredElementCollector(doc).OfClass(typeof(Group)).WhereElementIsNotElementType().ToElements() as IList<Element>;
                 foreach (Element group in groups)
                     Group g = group as Group;
GroupType GT = g.GroupType;
doc.Create.PlaceGroup(new XYZ(0, 0, 0), GT); }
If this helped solve your problem  mark it as solutionSmiley Happy
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
JimJia
hi,
Some wrong in your code: after break with foreach loop, the code after break will not be executed; I guess the tr.Commit() is not called, so the placement will not occur; you should move the tr.Commit() outside foreach.
Please try following fixed code, I verified it works:
    // your other code
// commit transaction after group placing
tr.Commit();
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Email: [email protected]
