Once Again: RevitAPI Transaction from ExternalWindow
Dear All,
I have read all the posts regarding my problem, however still I don't know how to solve it. I am using IExternalApplication interface to call a WPF Window (in my case - class TaskWindow) to perform some events in Revit API.
Obviously, the error I get: "Transactions are not allowed outside valid RevitAPI context" and I know that I should use ExternalEvents:
(https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/Revit-API/files/GUID-...)
However, due to lack of my knowledge, I am stuck a bit. Can someone of you guys, give me a hint in relation to my code below?
Much Appreciated, Lukasz
using System;
using System.Collections.Generic;
using System.Windows;
using System.Windows.Controls;
using Autodesk.Revit.DB;
namespace DockableDialogs
    public partial class TasksWindow : Window
        public Document Document = null;
        public List<Element> CheckedElements = new List<Element>();
        public TasksWindow(Document doc)
            InitializeComponent();
            this.Document = doc;
        private void Apply_Click(object sender, RoutedEventArgs e)
            //  <---    HOW TO IMPLEMENT SOLUTION HERE ? ---->
            using (Transaction tx = new Transaction(this.Document, "MarkChecked"))
                tx.Start();
                foreach (Element el in CheckedElements)
                    try
                        el.LookupParameter("SomeVisibilityParameter").Set(0);
                    catch (Exception ex)
                        MessageBox.Show(ex.Message);
                tx.Commit();
            this.Close();
        private void CheckBox_Checked(object sender, RoutedEventArgs e)
            //Get some elements for the CheckedElements list
            Element target = ((Element)((CheckBox)sender).Content);
            this.CheckedElements.Add(target);
jeremytammik
Look at the Revit SDK sample on external events.
If you are still stuck after that, you should give up and do something else  🙂
Jeremy Tammik
Developer Technical Services
The Building Coder
