how to verify label on element using revit api?
prasannamurumkar
Message 1 of 11
prasannamurumkar
hook is present in bathroom in given project.
Now wants to verify whether this hook is labeled by"HK" using revit api?
how do we that?
Replies (10)
Message 2 of 11
BardiaJahan
Assuming your question is about Tags (IndependentTag class in Revit API): tags are dependents of model elements. This means if you delete the element they will be deleted, then you can retrieve the tag ElementId and Rollback the transaction. Then retrieve the TagText property of the tag and compare it to "HK" or anything else.
Message 3 of 11
prasannamurumkar
Thank you for reply.
1.able to retrive tag
var doortag = new HashSet<ElementId>(collector1.OfClass(typeof(IndependentTag)).OfCategory(BuiltInCategory.OST_DoorTags).OfType<IndependentTag>().Select(x => x.GetTaggedLocalElement().Id).Where(x => x != null));
2.Able to retrive ElementID of tags.
foreach (ElementId i in doortag)
3.How to retrive Tag text property and how to compare with any particular name?
Could you give code for that.
Message 4 of 11
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @prasannamurumkar ,
I hope this will help
foreach(ElementId eid in tagElementIds)
                    Element e = doc.GetElement(eid);
                    IndependentTag Doortag = e as IndependentTag;
                    if(Doortag!=null)
                       if(Doortag.TagText=="Name to compare")
                            //Your code
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Message 5 of 11
prasannamurumkar
able to get element.For this
 Doortag is showing null.
Message 6 of 11
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @prasannamurumkar,
Your code collects the door not the door tag.
You can't cast door as independent tag.
Collect all doortags not doors and from the collected doortags try to get the tagtext.
Naveen Kumar T
Message 7 of 11
prasannamurumkar
but how to collect tags tried this one but not getting collect.
IEnumerable<Element> roomTags = new FilteredElementCollector(activeDoc, activeDoc.ActiveView.Id).OfCategory(BuiltInCategory.OST_RoomTags).WhereElementIsNotElementType().ToElements();
is this right?
or sholud try something else?
Message 8 of 11
naveen.kumar.t
Autodesk Support
Autodesk Support
Here the question is which tags you want to collect?
Do you want to collect Roomtags or DoorTags?
this code will help you to collect RoomTags
 FilteredElementCollector Collector = new FilteredElementCollector(doc,doc.ActiveView.Id).OfCategory(BuiltInCategory.OST_RoomTags).WhereElementIsNotElementType();
                IList<ElementId> eids = Collector.ToElementIds() as IList<ElementId>;
                foreach(ElementId eid in eids)
                    RoomTag IT = e as RoomTag;
                    string s=IT.TagText;
and this code will help you to collect DoorTags
FilteredElementCollector Collector = new FilteredElementCollector(doc,doc.ActiveView.Id).OfCategory(BuiltInCategory.OST_DoorTags).WhereElementIsNotElementType();
                    IndependentTag IT = e as IndependentTag;
I tested the above codes and both are working fine for me.
Naveen Kumar T
Message 9 of 11
prasannamurumkar
thank you it works fine.
Message 10 of 11
prasannamurumkar
Hi
Do we able to get relation between tag and its element?
as in above case  able to get independent tags of particular category.
for eg having 6 doors got 6 door tags in above case
suppose one of door does not have tag then it should able to find particular door does not having tag.
so it is require find relation between element category and element tag category.
Message 11 of 11
naveen.kumar.t
Autodesk Support
Autodesk Support
try using the below code
this code will highlight the elements which are not taggged
IList<ElementId> ElementsWithoutTag = new List<ElementId>();
                foreach(Element e in new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Doors).OfClass(typeof(FamilyInstance)))
                    if(new FilteredElementCollector(doc).OfClass(typeof(IndependentTag)).Cast<IndependentTag>().FirstOrDefault(q=>q.TaggedLocalElementId==e.Id)==null)
                        ElementsWithoutTag.Add(e.Id);
uidoc.Selection.SetElementIds(ElementsWithoutTag);
uidoc.RefreshActiveView();
If this helped solve your problem please mark it as solution, so other users can get this solutions as wellSmiley Happy
Naveen Kumar T
