Can't generate .JPG files for multi-level linked RVT files
impararia
impararia
Hello
We have the following Revit file structure and we are trying to generate by using the following APIs,  JPG files at all levels: at the top level ExportImage & at the children levels GetPreviewImage (on the RevitLinkType).
The GetPreviewImage return a null Bitmap for all low level links.
Is-there a way to use another APIs or approach to generate all JPGs for all levels at one time.
Link LevelNameLink TypeRelated JPG file
Regards
rosalesduquej
So actually this week I had a different question using GetPreviewImage as well and found a couple of limitations with it, where I was getting null back for GroupTypes for example. The way I have used it succesfully before is with FamilyInstances but I have never tried it with Revit files and neither with Linked files. So I have a suggestion for you, if what you want is to create a preview of those Linked files, Why not generate the pictures of the project documents that will look like the default 3D view in Revit yourself.
Here is a nice couple of post by Jeremy Tammik where explains how to create those higher quality preview images, you can create it yourself
http://thebuildingcoder.typepad.com/blog/2013/08/setting-a-default-3d-view-orientation.html
Here is another discussion about setting the background colour for that very purpose:
http://thebuildingcoder.typepad.com/blog/2013/12/setting-the-view-display-background.html
There a lots of examples of that on the blog. Hope you will find this beneficial to what you are trying to do.
Cheers,
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
