Element selection from dockable panel
Hi!
I trying to write plugin into Revit. I need highlight model from my dockable panel. I created two buttons, on this panel, one of them selects all walls and the other - all floors. I am using next code for this selection.
  public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIDocument uiDoc = commandData.Application.ActiveUIDocument;
            uiDoc.Selection.SetElementIds(Manager.GetAllElements());
            return Result.Succeeded;
When I press button and return focus to Revit it works fine.
But there are some strange behavior in Revit. If I choose walls at start, then choose floors, return to Revit I will see that floors will be selected there. It`s ok. When I deselect all elements in Model-view (3D-view), than click on dockable panel and go back to Revit, it will select walls (elements which was chosen in the penultimate step).
I use Revit Architecture 2016 .
Have you any idea why it happens?
Thank you!
Aaron.Lu
This should be a known issue, if you upgrade Revit, the problem might disappear
Aaron Lu
Developer Technical Services
Autodesk Developer Network
tsc444
I'm having the same exact issue. Could you please confirm if this is a known bug and if it has been fixed?
tsc444
DId you ever find out what the problem was? I'm having the same exact issue and cannot come up with a solution in Revit 2016.
