Can't create wall foundation
Sydra7
Sydra7
Sample code:
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
try
var document = commandData.Application.ActiveUIDocument.Document;
Transaction transaction = new Transaction(document, "Create Footing");
transaction.Start();
var wall = (new FilteredElementCollector(document).OfClass(typeof(Wall))).ToList()[0] as Wall; //I placed a wall with hand!
var foundationType = document.GetElements<ContFootingType>().ToList()[0];
var continuousFooting = document.Create.NewFoundationWall(foundationType, wall);
transaction.Commit();
catch
return Result.Failed;
return Result.Succeeded;
Exception:
"A first chance exception of type 'System.Runtime.InteropServices.SEHException' occurred in RevitAPI.dll
Additional information: External component has thrown an exception."
What is wrong with the footing creation?
(I use Revit 2013 API)
Regards
David Schmidt
jeremytammik
Dear David,
I am sorry to inform you that there was an issue with the NewFoundationWall method in Revit 2013.
It has been fixed in Revit 2014.
I found this information searching through my old ADN issues and encountering case 07700489 [Error when creating a new foundation wall] and SPR #230113 [NewFoundationWall does not work] that I explored back in October 2012.
Sorry for the bad news for Revit 2013, and happy to let you know it should work fine in Revit 2014.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
