Viewport label size and location
BobbyC.Jones
BobbyC.Jones
How can I adjust the location and size of a Viewport label?  This is what I've tried without success:
using (var trans = new Transaction(activeDoc))
    trans.Start("Reset Label");
    Outline labelOutline = newViewport.GetLabelOutline();
    labelOutline.MinimumPoint = desiredMinXyz;
    labelOutline.MinimumPoint = desiredMaxXyz;
    trans.Commit();
 Thanks!
Bobby C. Jones
Hi Bobby C. Jones ,
Did you try with different value in Outline.MaximumPoint and Outline.MinimumPoint ?
And for the size, this should have worked Outline.Scale (double scale) -> Scales the bounding box by given scale.
Code snippet in Jeremy's blog might be useful here -
http://thebuildingcoder.typepad.com/blog/2010/09/view-location-on-sheet.html
Does it help ?
Partha
BobbyC.Jones
Hi Partha,
I've tried modifying both the Min & Max points and I've tried scaling the label outline to no avail.  The view label does not change size or location.
Jeremy's code does work to position views, but it doesn't address the labels.
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            Document activeDoc = commandData.Application.ActiveUIDocument.Document;
                trans.Start("Scale Viewport Label");
                ViewSheet activeSheet = commandData.Application.ActiveUIDocument.ActiveView as ViewSheet;
                Viewport firstViewPort = activeSheet.GetAllViewports().Select(activeDoc.GetElement).First() as Viewport;
                Outline firstViewPortLabelOutline = firstViewPort.GetLabelOutline();
                firstViewPortLabelOutline.Scale(2.0);
                trans.Commit();
            return Result.Succeeded;
                XYZ currentMinPoint = firstViewPortLabelOutline.MinimumPoint;
                XYZ currentMaxPoint = firstViewPortLabelOutline.MaximumPoint;
                XYZ newMinPoint = currentMinPoint + new XYZ(1, 1, 0);
                XYZ newMaxPoint = currentMaxPoint + new XYZ(1, 1, 0);
                firstViewPortLabelOutline.MinimumPoint = newMinPoint;
                firstViewPortLabelOutline.MaximumPoint = newMaxPoint;
                trans.Commit();
Bobby C. Jones
HI BobbyC.Jones , Are you solved that problem, i still have same problem with you.I want to use API to move instance Label of viewport no need to edit family, in API has method ViewPort.GetLabelOutline, this method to get the Outline of Label of ViewPort, i think we must to have solution to set the Outline of Label, if not the method ViewPort.GetLabelOutline is no meaning.
P/s: i make a code to duplicate view and place duplicated view on new sheet with same location, everything is ok, just the location of label still not same location (because original label'location moved so duplicated viewport'label can not same).
BobbyC.Jones
Sorry, I still have no solution to this problem.
Bobby C. Jones
Revitalizer
Hi Bobby C. Jones and others,
seems that this thread's topic is similar to this thread's, since both are about modifications of the label:
http://forums.autodesk.com/t5/revit-api/move-title-of-a-viewport/td-p/5598602
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
miguelmachadoecosta
