Can't create floor with hole
Sydra7
Sydra7
If i draw curves  (with mouse/hand) for floor with hole in revit, the program can make the floor from them. The NewFloor api function can't make the same ... why?
Sample code:
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
try
var document = commandData.Application.ActiveUIDocument.Document;
Transaction transaction = new Transaction(document, "Create Floor");
transaction.Start();
var points1 = new List<XYZ>() //for outer contour
new XYZ(8.0, 0.0, 0.0),
new XYZ(0.0, 8.0, 0.0),
new XYZ(0.0, 0.0, 0.0)
var curves = new CurveArray();
curves.Insert(document.Application.Create.NewLine(points1[0], points1[1], true), 0);
curves.Insert(document.Application.Create.NewLine(points1[1], points1[2], true), 1);
curves.Insert(document.Application.Create.NewLine(points1[2], points1[0], true), 2);
var points2 = new List<XYZ>() //for hole
new XYZ(4.0, 1.5, 0.0),
new XYZ(1.5, 4.0, 0.0),
new XYZ(1.5, 1.5, 0.0)
curves.Insert(document.Application.Create.NewLine(points2[0], points2[1], true), 3);
curves.Insert(document.Application.Create.NewLine(points2[1], points2[2], true), 4);
curves.Insert(document.Application.Create.NewLine(points2[2], points2[0], true), 5);
var floorTypes = new FilteredElementCollector(document).OfClass(typeof(FloorType));
var floorType = floorTypes.ToList()[0] as FloorType;
var levels = new FilteredElementCollector(document).OfClass(typeof(Level));
var level = levels.ToList()[0] as Level;
var floor = document.Create.NewFloor(curves, floorType, level, true);
transaction.Commit();
catch
return Result.Failed;
return Result.Succeeded;
Error message:
"Can't make Extrusion."
How can i create floor with holes?
(I use Revit 2013 API)
Regards
David Schmidt
jeremytammik
Dear David,
Yes, that is a known  issue.
Please see the following discussions on The Building Coder:
http://thebuildingcoder.typepad.com/blog/2009/05/hole-in-a-floor.html
http://thebuildingcoder.typepad.com/blog/2013/07/create-a-floor-with-an-opening-or-complex-boundary....
As you see, it can be worked around. Sorry that it is not more straighforward, as you had initially hoped.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Sydra7
Thanks for that! 🙂
Have a nice day!
