Can not import dll file into another project
thefriends98
Observer Observer
thefriends98
Observer
Observer
Hi everyone,
I’m running into an issue and wondered if anyone’s seen it before:
I built a class-library project and compiled it into a DLL, then referenced that DLL from another project. Everything worked fine at first, but after I updated the library and rebuilt the DLL, calling a brand-new method now fails with an error saying the assembly can’t be found.
Has anyone else ever encountered this?
Mohamed_Arshad
Hi @thefriends98
Kindly check the below link, Same topic already discussed in the forum
Solved: System.TypeLoadException: Could Not Load Type, is the exception I get when Im trying to load...
Thanks & Regards,
Mohamed Arshad K
thefriends98
Observer
Observer
Thanks @Mohamed_Arshad for your solution.
