Is Same between .OfClass(typeof(FamilySymbol)) and .WhereElementIsElementType() ?
XARMA
XARMA
I think
return familyType and
return familyType also. but then Why are they exist both?
Mohamed_Arshad
Hi @XARMA
You have a slight misunderstanding on this. As you mentioned, FamilySymbol returns a FamilyType. However, in Revit, some elements don't have a definite type and instead fall under the general Element category. For example, a 3DSectionBox has no specific type—it is classified under Element. These kinds of elements are filtered using the WhereElementIsElementType() method.
Hope this will Helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
TripleM-Dev.net
@Mohamed_Arshad, are you sure.
I never assumed that, always assumed it returns all elements derived from ElementType (like documentation states: https://revapidocs.com/2020.htm?id=77793daa-5a26-b4d6-9019-4d998a55099e.htm )
@XARMA
.OfClass(typeof(FamilySymbol)) returns FamilySymbol elements, which is derived from ElementType
.WhereElementIsElementType() will return ElementType's, some may be FamilySymbol but doesn't have to be.
For instance take a Door familytype and a Wall type.
.OfClass(typeof(FamilySymbol)) will only return the Door familytype as it's derived from FamilySymbol and WallType isn't
.WhereElementIsElementType() will return both door and wall type because both are derived from ElementType
So depending what's you need UserFamily Type or all types will determine which to use.
- Michel
Ps Use RevitLookup addin to inspect how different elements are build.
Mohamed_Arshad
Hi @TripleM-Dev.net
Thank you for your clarification :). I miss understood the concept of WhereElementIsElementType(), It is returning the base class (Type).
Mohamed Arshad K
