C# programming
C# programming
C# programming
How much C# programming is useful in revit customization. I don't have any idea about this. Please help in this.
stm
augusto.goncalves
Please check our "getting started" material at www.autodesk.com/myfirstrevitplugin
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Balaji_07
Download and install the Revit SDK from the below link
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2484975
You can find a large collection of C# API samples in the "Samples" folder. This will give you enough idea on Revit Customization using C#
Balaji A
Accept this post as Solution if  you found it usefull and don't forget to hit Kudos! Cat Wink
This is hard to believe as an actual question.  For one thing, it is entirely too broad.. "How much is programming useful?"  Doing what, exactly?  It isn't very far away from "What is programming?"
MarryTookMyCoffe
He even have a rank Advocate
do not worry it only gonna take Autodesk 5 years to fix bug
