Can I tell program to wait?.... (closing and reopening document problem)
I am not sure if I should post this on this forum as it might more a C# specific problem.
I am Closing and re-opening a file in the same program and this causing revit to have an unrecoverable error.
Is there any way for me to wait a couple of seconds before reopening it?
I am trying to avoid using threads because its my achillees heal in programming. So if there is any other options or advice I would love to hear them.
If it helps I am using the building coder's program here as a basis
http://thebuildingcoder.typepad.com/blog/2012/12/closing-the-active-document.html
Instead i am opening the placeholder, closing the main project and then opening the main project and closing the placeholder
Thank you in advance,
Jack
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Application app = uiapp.Application;
            Document doc = uidoc.Document;
            string filename = "_placeholder_.rvt";
            string docPath = Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments);
            string myPath = Path.Combine(docPath, filename);
            string userPath = doc.PathName;
	        m_CloseHelper = new UiCloseHelper(uiapp,myPath);
	        m_CloseHelper.CloseAndSave(uidoc);
            TaskDialog.Show("next", "Now lets re-Open the file");
            //********************crashes here***********************//
            m_CloseHelper = new UiCloseHelper(uiapp, userPath);
            return Result.Succeeded;
I believe the DocumentClosed  event was what I needed.
jeremytammik
I believe so too  🙂
If you really want to wait for a specific amount of time, you can use the .NET and Windows API function Thread.Sleep to do so.
There are some samples on using it on The Building Coder.
Asking for notificfation from Revit when the document really has closed is a much better approach, though.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Hi Jeremy
I have handled the event but the program still seems to be crashing. I can't figure out what is happening and I have been stuck on this for a few days.
I hope it is not down to poor coding, I am still a junior developer.
Here is my code if anyone wants to take a look at it, I don't want to hassle people though.
Thank you,
Jack
jeremytammik
Dear Jack,
I think that the following two lines will not work as you are hoping:
            while ((closed == false) || (saved == false)){
The will hog all the execution.
The Revit API does not support multi-threading.
I think you will have to re-think.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
This is my original code, seems pretty straight forward to me but still causes and unrecoverable error 😞
In code above i was handling the document.closed event with a piece of code that closed a document. dumb mistake on my part, sorry
