BuiltInCategory.OST_MatchAll doesn't work when adding new shared parameter
demapavlo
demapavlo
Hello. I wrote a plug-in thats adds new shared parameter and I want it to be visibile for all categories. I am using
categorySet.Insert(doc.Settings.Categories.get_Item(BuiltInCategory.OST_MatchAll));
But when launching the plug-in I get following error
Any suggestions on how to select all categories?
jeremy_tammik
Well, the error message say that one of the categories in the input item is null. Since you are only providing a single input, OST_MatchAll, that does not have a matching category in the Document. Makes sense, doesn't it?
However, you need a valid category in the document to call the Insert method. Afact, one way to solve this would be to retrieve all the document categories one by one and add your shared parameter to each of them. I assume this also matches the UI behaviour.
