Sort/Grouping field in schedule
nia98bim
nia98bim
hey everyone , I create a wall schedule ,but I want to sort by type in API .
i read the topics regarding that but still couldnt find way for that.
using System;
using System.Linq;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.Attributes;
namespace Schedule
    [Transaction(TransactionMode.Manual)]
    public class ExportSchedule : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Document doc = uidoc.Document;
            try
                using (Transaction trans = new Transaction(doc, "Create schedule"))
                    trans.Start();
                    // Create a new schedule
                    ViewSchedule wallSchedule = ViewSchedule.CreateSchedule(doc, new ElementId(BuiltInCategory.OST_Walls));
                    wallSchedule.Name = "Wall Schedule";
                    // Add 'Type' field
                    SchedulableField typeField = wallSchedule.Definition.GetSchedulableFields()
                        .FirstOrDefault(sf => sf.GetName(doc).Equals("Type"));
                    if (typeField != null)
                        wallSchedule.Definition.AddField(typeField);
                    else
                        throw new Exception("Type field not found in schedule definition.");
                    // Add 'Area' field
                    SchedulableField areaField = wallSchedule.Definition.GetSchedulableFields()
                        .FirstOrDefault(sf => sf.GetName(doc).Equals("Area"));
                    if (areaField != null)
                        wallSchedule.Definition.AddField(areaField);
                    else
                        throw new Exception("Area field not found in schedule definition.");
                    // Sort by 'Type' field
                    ScheduleSortGroupField sortField = new ScheduleSortGroupField(typeField.ParameterId, ScheduleSortOrder.Ascending);
                    wallSchedule.Definition.ClearSortGroupFields();
                    wallSchedule.Definition.AddSortGroupField(sortField);
                    trans.Commit();
                TaskDialog.Show("Success", "Wall Schedule created successfully.");
                return Result.Succeeded;
            catch (Exception ex)
                message = ex.Message;
                return Result.Failed;
but in this part of code there is problem that i have no idea to how to solve it !
(type Field is not able to convert parameter id )
here is the link below that I used for sort/group.
sort/grouping apidoc
thank you in advance.
jeremy_tammik
Does this fundamental article help?
nia98bim
thank you for your reply, I saw that article , but actually is not help me .
my problem is what item should place in schedule field id  to sort and itemize walls by type .
https://www.revitapidocs.com/2024/e437cc01-b976-fe8a-225a-1a0024171fae.htm
nia98bim
