BuiltInCategory of Doors and curtain wall doors
desdinova
Message 1 of 18
desdinova
Hi friends,
I want to built a plugin that changes the curtain wall panel types
when I try to select curtain wall door how can I filter only panel doors for curtain wall
Is there any specific value for curtain panel door?
Thanks in advance....
Replies (17)
Message 2 of 18
jeremytammik
As you show in your screen snapshots, the category os the same for all doors, so that cannot be used to tell them apart.
Another possible criteria could be to query the door for its host using its `Host` property:
https://www.revitapidocs.com/2020/69f30141-bd3b-8bdd-7a63-6353d4d495f9.htm
Using the host element properties, you ought to be able to differentiate curtain walls from others.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 3 of 18
desdinova
Hi Jeremy,
Thanks for reply
I think Host property returns value when the door is placed on the wall.
When i collect familysymbols in door category is it possible to differentiate doors and curtain panel doors?
Thanks again.
Message 4 of 18
jeremytammik
Oh yes, in that case, of course, the Host property will not be set.
I am sure you can tell them apart somehow. I cannot tell you how. You might be able to tell by their geometry, parameters, family definition name, dimensions, or other criteria unknown and inaccessible to me.
It is up to your imagination to research and find out...
Jeremy Tammik
The Building Coder
Message 5 of 18
desdinova
Thanks Jeremy,
I think I need to study on parameters or create a parameter for curtain wall doors
thanks again.
Message 6 of 18
BenoitE&A
I would not do that, I would rather use Jeremy's hint : find the host and check if it is a Curtain Wall. The parameter for Curtain Walls is: myWall.CurtainGrid which is not null if your wall is a Curtain Wall.
So it is easy to search for such a door :
FamilyInstance door = null;
if((door.Host as Wall).CurtainGrid!=null)
             // That's my door
Benoit FAVRE
CEO of etudes & automates
www.etudesetautomates.com/
Message 7 of 18
desdinova
Hi Benoit,
Thanks for reply,
Host property is usable when the door is hosted on wall.
But I need to differentiate doors and curtain wall doors in familysymbol level.
Thanks again.
Message 8 of 18
FAIR59
From the FamilySymbol you can find similar types using FamilySymbol.GetSimilarTypes().
This gives you all curtainwall-panels, that can be placed in a curtain wall. Filter the list for the door-category.
FamilySymbol symbol = inst.Symbol;
IEnumerable<FamilySymbol> CW_doors = new FilteredElementCollector(doc, symbol.GetSimilarTypes())
            	.OfCategory(BuiltInCategory.OST_Doors)
            	.Cast<FamilySymbol>();
Message 9 of 18
Revitalizer
there is a Family.IsCurtainFamily property.
So you could check:
FamilyInstance.Symbol.Family.IsCurtainFamily
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 10 of 18
desdinova
Thanks Fair59
It works...
Message 11 of 18
desdinova
Hi Revitalizer,
Thanks for reply.
But IsCurtainFamily property always returns false.
How can İ solve
I attach the code and rvt file.
Thanks again..
FamilyInstance familyInstance = doc.GetElement(uidoc.Selection.PickObject(ObjectType.Element)) as FamilyInstance; FamilySymbol symbol = familyInstance.Symbol; if(symbol.Family.IsCurtainPanelFamily) { TaskDialog.Show("Revit", "true"); } else { TaskDialog.Show("Revit", "false"); }
Message 12 of 18
Revitalizer
yes, I can see that in the file.
Sorry for confusion.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 13 of 18
rhanzlick
This topic, appears at least partly resolved, but I would use the Kind property of the host's WallType. Given a list of all doors in project, I would filter using a lambda expression:
doorList.Where(door=>door.Host != null && door.Host is Wall).Where(door=>(door.Host as Wall).WallType.Kind == WallKind.Curtain).ToList();
Hope this works for you.
Message 14 of 18
2550798990
By parameter: “FamilyPlacementType”
if (_familySymbol.Family.FamilyPlacementType == FamilyPlacementType.OneLevelBased)//OneLevelBased 幕墙门窗
else if (_familySymbol.Family.FamilyPlacementType == FamilyPlacementType.OneLevelBasedHosted)//OneLevelBasedHosted 普通门窗
Message 15 of 18
Sean_Page
This is how I usually determine it, but again that is after it is hosted.
Sean Page, AIA, NCARB, LEED AP
Senionr Partner, Computational Designer, Architect
Message 16 of 18
rhanzlick
Upon reading this again, I think my previous answer did not correctly interpret what the OP was asking. From what I can tell, your best bet will likely be to access the "Host" parameter (BuiltInParameter.FAMILY_HOSTING_BEHAVIOR):
door.Symbol.Family.Parameters("Host").AsValueString()
This string should be empty for door families based on curtain panel template, and will be "Wall" for other standard door types. Have not tested this extensively, but so far it looks like it works well as an a priori filter for any family.
Message 17 of 18
dbrokaw44TRW
If you were hell-bent on not using, IsCurtainPanelFamily Property, with parameters, you may be able to determine it with the following:
 Parameter wallClosureParam = door.LookupParameter("Wall Closure");
get_Parameter(BuiltInParameter) ; enum TYPE_WALL_CLOSURE
get_Parameter(BuiltInParameter) ; enum DATUM_PLANE_DEFINES_WALL_CLOSURE
Left is Door, Right is Curtain Door Family template .rtf.
Maybe....?
Message 18 of 18
sensiblehira
Revit lookup is giving the value as false for all curtain panel families. It would have been helpful if the value was assigned to it.
