Broken Mesh with TessellatedShapeBuilder
I am trying to create a mesh in Revit using TessellatedShapeBuilder, with the mesh data coming in from a different data model. I am creating faces and adding the faces to the shapebuilder. Please see the code attached.
In the end I add the mesh to the document using DirectShape. And the resulting mesh looks as shown in the picture. Why is the mesh all broken ? The source mesh is normal looking.. looks like a spaceship, but this one is broken. I thought maybe it has something to do with face normals ? Or is there some behavior of tessellatedshapebuilder that I am missing ? What am I doing wrong ?
jeremytammik
I guess there are a lot of things you might be doing wrong.
No idea what they may be.
I cannot read your code from an image.
Here is a list of some issues I addressed and solved creating direct shape elements from quite complex OBJ source files:
http://thebuildingcoder.typepad.com/blog/2015/02/from-hack-to-app-obj-mesh-import-to-directshape.htm...
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Here is the source code:
(ppm) => {
  rg.TessellatedShapeBuilder builder = new rg.TessellatedShapeBuilder();
  builder.OpenConnectedFaceSet(true);
  builder.Target = rg.TessellatedShapeBuilderTarget.Mesh;
  builder.Fallback = rg.TessellatedShapeBuilderFallback.Salvage;
  List<rg.XYZ> allVerts = ppm.Vertices.Select((pt) => ptConv.FromPipe<rg.XYZ, ppg.Vec>(pt)).ToList();
  foreach (var face in ppm.Faces)
    List<rg.XYZ> faceVerts = new List<rg.XYZ>();
    foreach(ulong vertIndex in face)
      faceVerts.Add(allVerts[(int)vertIndex]);
    rg.TessellatedFace tface = new rg.TessellatedFace(faceVerts, rg.ElementId.InvalidElementId);
    //if (!builder.DoesFaceHaveEnoughLoopsAndVertices(tface)) { continue; }
    builder.AddFace(tface);
  builder.CloseConnectedFaceSet();
  builder.Build();
  rg.TessellatedShapeBuilderResult result = builder.GetBuildResult();
  List<rg.GeometryObject> geoms = result.GetGeometricalObjects().ToList();
  return (rg.Mesh)geoms.FirstOrDefault();
I saw that article before and the airplane seems to be the closest match, which is caused by smoothing groups, but I don't have any smoothing groups.
Is there any other way to debug this and find out what exactly is going wrong with DirectShape ?!
Thanks !
I was able to export simpler meshes (spheres and cubes) and they work just fine. So that eliminates the face normal issue. Its only happening with complex shapes.
