Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
BRepBuilder fails without explanation
5 REPLIES 5
jfaulkner-evolve
377 Views, 5 Replies
A sample file is attached.
All the edges are correctly oriented & ordered in the faces. All the faces are facing out. We have tried making BRepBuilderSurfaceGeometry with and without bounds and it fails either way.
Thanks in advance for any help.
5 REPLIES 5
Thank you for your samples code snippet. It includes a selection filter to pick a very specific fabrication part.
Hence, I have no idea how to run it, in which model, and what element to select.
Please provide a minimal complete reproducible case including the sample model, detailed instructions, steps to reproduce the problem and succinct description of the expected versus observed behaviour.
Thank you for the response - my colleague will post a reply with the requested information.
@jeremy_tammik It just requires a rectangular fabrication duct. Here's an example model with a rectangular fabrication duct (placed at the origin for debugging ease).
Hi @jfaulkner-evolve,
Thank you for your patience.
I analysed the sample code and sample file and encountered the same issue. I am not sure what is causing the issue; I have submitted the same to the Revit Engineering team for further analysing with ticket REVIT-206810 - BRepBuilder fails.
I will come back to you as soon as I receive a response from the engineering team.
  Moturi George,     Developer Advocacy and Support,  ADN Open
The engineering team has responded to the issue raised above.
"This appears to be a case of user error. The created on line 55 of the attached txt file has the wrong orientation:
var face1Id = builder.AddFace(face1, !(Math.Abs(connectors[1].Width - (connectorInfo0.Width)) < 0.001));
I didn't try to determine what the logic that computes the flag should be, but when I invert the second argument, the BRep is created successfully."
Kindly try again on your end
Forma Design Contest
Rail Community
