I have an electrical load with 9 connectors and would like to automatically connect each of them to a panel by having the user select the load and panel. My current approach is to create an electrical system for each connector and set the panel. I am able to create electrical systems, however when I use the SelectPanel method and pass in the panel, I am given the error "The panel and circuit do not match".
The panel and load are the same voltage and both have the same number of phases. I am able to manually connect them (Select load, click Power, ect...) without any problems, so why am I getting an error here? Here is the snippet of code in which I create the electrical system for one connector and attempt to select the panel (load and panel are both FamilyInstance types):
TransactionManager.Instance.EnsureInTransaction(doc) newElectricalSystem = Autodesk.Revit.DB.Electrical.ElectricalSystem loadConnectorIterator = load.MEPModel.ConnectorManager.UnusedConnectors.ForwardIterator() loadConnectorIterator.MoveNext() loadConnector = loadConnectorIterator.Current circuit = newElectricalSystem.Create(loadConnector, ElectricalSystemType.PowerCircuit) TransactionManager.Instance.TransactionTaskDone() circuit.SelectPanel(panel)
I am using Revit 2019 and coding in Python using Dynamo
Solved by opferjohn. Go to Solution.
I believe the Revit SDK PowerCircuit sample demonstrates some of the functionality you require. Please take a look at that.
Thanks for the reply @jeremytammik . I placed another panel(same family and type as the first), ran it with the same code, and it worked and works for all other panels I am using this code with. I'm not sure why it was giving me errors before, but all is well now.
