Automatic window dimensioning with Dynamo
leeUT3Y6
leeUT3Y6
Hi everyone,
I'm trying to add a simple linear dimension using Dynamo, with the Genius Loci package — but with no success.
The dimension elements are created (I can see them in Dynamo and find them by ID in Revit), but they don’t appear in the view.
I’ve attached a snippet and the code.
Has anyone managed to successfully create dimensions in Dynamo?
PYTHINKS
- Hi!
- First this is a forum about Revit API, not about Dynamo
- You have found help here: https://forum.dynamobim.com/
- Also, please use the Export As Image function to export high quality photos, based on the image you provide, I cannot know where the problem is
leeUT3Y6
This image was exported using the "Export as Image" function at the highest quality setting.
I've also attached the code itself  - That's the highest quality export possible 🤣
This seems to be more of a Revit API issue.
The problem seems to be in the way Revit expects dimensions to be created
