Revit Links Halftone, Underlay checking
mohd_danishCX582
Observer Observer
204 次查看
1 条回复
1 条消息(共 2 条)
mohd_danishCX582
Observer
Observer
Is there any possible way to check whether the Revit link is half-tone or not in a view?
Cause I didn't find anything in Revit Lookup. I also used Override Graphic Settings, and it always gives halftone as false.
UIDocument uidoc = this.ActiveUIDocument;
Document doc = uidoc.Document;
Autodesk.Revit.DB.View view = doc.ActiveView;
Reference sel = uidoc.Selection.PickObject(ObjectType.Element,"select Revit Link") ;
Element e =doc.GetElement(sel.ElementId);
if (e != null)
    bool isLinkHalftone = false;
    OverrideGraphicSettings ogs = view.GetElementOverrides(e.Id);
    if(ogs.Haltone == true)
       isLinkHalftone = true;
205 次查看
1 条回复
回复 (1)
2 条消息(共 2 条)
Mohamed_Arshad
Hi @mohd_danishCX582
From Revit 2024 Autodesk added a GetLinkOverrides Method it returns RevitLinkGraphicsSettings Object but this class access for only for DisplaySetting, still Halftone and Underlay not yet added. Kindly check the below already discussed threat.
Revit links graphic overrides - Autodesk Community
If possible kindly add at Idea Station. @naveen.kumar.t  any insights on this.
Mohamed Arshad K
Software Developer (CAD & BIM)
