Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
assembly reference error
5 REPLIES 5
814 Views, 5 Replies
I am getting "the type name or namespace name 'Revision' could not be found (are you missing a using directive or assembly reference?)" error while excuting for the same i have attached screen shot.
What is the assembly reference for this revision class, i am using Revit Structure 2014 in pc .
expecting solutions from experts.
Regards
Amith
Regards
Amith
5 REPLIES 5
rosalesduquej
rosalesduquej
Autodesk Support
Autodesk Support
Dear Amith,
Did you copy the code you are using from another project where Revision Namespace existed and you forgot about it?
This error it is pretty self explanatory. It is telling you that a missing Assembly reference cannot be found in your code and you are referencing to it. I know it sounds repetitive but that is pretty much it. See the following link.
https://support.microsoft.com/en-us/kb/304656
The screenshot provided does not help, since there is not a lot of information other than the one you already described. So, maybe providing a bit more information about your code will help the community identify what you are missing.
Cheers,
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
Dear Amith,
Cheers,
Jaime Rosales D.
in reply to: rosalesduquej
Dear Jaime,
As i know that this reision class is newly added in revit 2015, Hope it will not work in 2014.
Regards
Amith
Dear Jaime,
Regards
Amith
rosalesduquej
rosalesduquej
Autodesk Support
Autodesk Support
Dear Amith,
Yes you are correct, this class got its first version on Revit 2015, so unfortunately 2014 will not have access to such class, sorry for the bad news.
Cheers,
Jaime Rosales D.
Dear Amith,
Cheers,
Jaime Rosales D.
atk_vinay.krishna
Is there any alternatate way to create revision clouds
rosalesduquej
Autodesk Support
Autodesk Support
Dear Vinay,
I did a quick search and I saw a couple of post by Jeremy where he points out that the Revision class was one of the major implementations for Revit API 2015.
One of the major Revit 2015 API additions is access to revisions.
All prior versions provided very limited access to revision data in a project. Here are some things people achieved in spite of the limitations:
But if you read a bit more you will see there is a Wrapper Class that another API 3rd party developer used to bypass the limitation of the non-existency in Revit 2014 for example.
Here is the link from where I'm quoting Jeremy. http://thebuildingcoder.typepad.com/blog/2014/06/the-revision-api-and-a-form-on-the-fly.html
And here is Max's Revision Wrapper Class for you to use in Revit 2014 http://thebuildingcoder.typepad.com/blog/2013/09/max-revision-wrapper-class.html
Cheers,
Jaime Rosales D.
Dear Vinay,
Cheers,
Jaime Rosales D.
