Rotate problem
Rotate problem
Rotate problem
Hi
I read an article ( Text File Driven Automatic Placement of Family Instances ) from Jeremy Tammik's blog
For Know , I know the way to create instances by a text file contains XYZ coordinates , then I try to rotate the instances at the same time .
But it seems to be not successful . Here's the picture of my consequence.
As you see , it create several times by different angles...
But what I really want is like the picture below that every instance has different angle.
And here's my key code(which came out the unsuccessful picture).
foreach (XYZ p in Points)
  foreach( double d in Degree)
    familyInstance = creation_doc.NewFamilyInstance(p, Type, st);
    XYZ p2 = new XYZ(p.X, p.Y, p.Z + 10);
    Line axis = Line.CreateBound(p, p2);
    ElementTransformUtils.RotateElement(doc, familyInstance.Id, axis, d);
I don't know how to correct it .
Please do help me , thank you .
As I see it you are going through all the points
and add a family on each rotation point:
{  foreach( double d in Degree)
Insert + Rotate
This means you will get way to many families, actually the corect inserted and rotated family is simply covered by all the wrong ones..
so you need to only insert ONE family per coordinate, and THEN insert and rotate it.
if your Points and Rotations are in a List<> then you can use its index to find the respected double (depending on your text file)
in semi-psudocode:
i == 0;
if(Points.Count == Degrees.Count)
for(int i = 0, i < Points.Count, i++) {
XYZ p = Points[i];
double d = Degrees[i];
insert family on p and rotate with d bla bla
... you know what to do...
or if you work with a number of text files or need more flexibility you need to create your own list of a class where you store each XYZ and double and then go through them..
Hope this helps...
