I've created some detail items from the API, and I want to ask user to select an insertion point.
I want the draw a box or the the element I've created when the user moves the cursor, like Revit does when moving or adding a new element.
How can I achieve this behavior?
Solved by jeremy_tammik. Go to Solution.
That is a good idea. The Revit API does not add full support for this functionality, unfortunately. You can achieve something similar in two ways that I am aware of:
The PromptForFamilyInstancePlacement and PostRequestForElementTypePlacement methods prompt the user to place instances of a specified FamilySymbol and display a preview of the placement using the built-in Revit family placement functionality:
However, they are asynchronous, so not wholly integrated into the add-in code.
A sketchier preview can be achieved by drawing some transient graphics of your own to simulate what is known in AutoCAD as a jig:
