project parameters are not shown after transfering it
Hans_Dwe
Message 1 of 10
Hans_Dwe
Hello !! I am working on transferring Project Parameters from a source document to a target document, it worked and showed me in the log that they have been successfully transferred but in the target document when I looked up Manage > project parameters none of these parameters were shown there, so what it could be the problem. and here is a part of the code. Thanks
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.Attributes;
using System;
using System.Collections.Generic;
using System.Linq;
using System.IO;
namespace TransferProjectParameter
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
    public class Class1 : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIApplication uiapp = commandData.Application;
            Document sourceDoc = uiapp.ActiveUIDocument.Document;
            // Collect all project parameters from the source document
            BindingMap sourceBindingMap = sourceDoc.ParameterBindings;
            DefinitionBindingMapIterator iter = sourceBindingMap.ForwardIterator();
            iter.Reset();
            List<Definition> projectParameters = new List<Definition>();
            while (iter.MoveNext())
                Definition def = iter.Key;
                projectParameters.Add(def);
            Document targetDoc = null;
            foreach (Document doc in uiapp.Application.Documents)
                if (!doc.Equals(sourceDoc))
                    targetDoc = doc;
                    break;
            using (Transaction trans = new Transaction(targetDoc, "Copy Project Parameters"))
                trans.Start();
                BindingMap targetBindingMap = targetDoc.ParameterBindings;
                foreach (var def in projectParameters)
                    Binding binding = sourceBindingMap.get_Item(def);
                    if (binding != null)
                        // Get the parameter group
                        BuiltInParameterGroup paramGroup = (def as InternalDefinition)?.ParameterGroup ?? BuiltInParameterGroup.INVALID;
                        // Add the definition with the same binding to the target document
                        targetBindingMap.Insert(def, binding, paramGroup);
                trans.Commit();
            List<string> projectParameterNames = projectParameters.Select(p => p.Name).ToList();
            TaskDialog.Show("Transfer Project Parameters", $"{projectParameters.Count} project parameters transferred successfully.");
            return Result.Succeeded;
Replies (9)
Message 2 of 10
Mohamed_Arshad
HI @Hans_Dwe
    I checked your code, Most of the things are correct but we can't directly bind other projects' InternalDefintion, we need to convert from InternalDefinition to ExternalDefintion. I added small code snippet as a region and modified your code a little bit, Kindly refer to the below code.
Modified Code:
using System;
using System.Linq;
using System.IO;
using Microsoft.Office.Interop.Excel;
using System.Xml.Linq;
        private string logFilePath = @"C:\log.txt";
            iter.Reset();
            if (projectParameters.Count == 0)
                TaskDialog.Show("Error", "No project parameters found in the source document.");
                return Result.Failed;
                    targetDoc = doc;
                    break;
            if (targetDoc == null)
                TaskDialog.Show("Transfer Project Parameters", "No target document found.");
            #region Convert Internal Definition to External Defintion
            string originalSharedParameterFile = uiapp.Application.SharedParametersFilename;
            string tempFile = Path.GetTempFileName() + ".txt";
            using (File.Create(tempFile)) { }
            uiapp.Application.SharedParametersFilename = tempFile;
            Dictionary<ExternalDefinition, Definition> extDef = new Dictionary<ExternalDefinition, Definition>();
            foreach (Definition definition in projectParameters)
                ExternalDefinitionCreationOptions creationOpt = new ExternalDefinitionCreationOptions(definition.Name, definition.ParameterType);
                ExternalDefinition def = uiapp.Application.OpenSharedParameterFile().Groups.Create("TemporaryDefintionGroup").Definitions.Create(creationOpt) as ExternalDefinition;
                extDef.Add(def, definition);
            uiapp.Application.SharedParametersFilename = originalSharedParameterFile;
            File.Delete(tempFile);
            #endregion
            // Add project parameters to the target document
                trans.Start();
                foreach (KeyValuePair<ExternalDefinition,Definition> def in extDef)
                    Binding binding = sourceBindingMap.get_Item(def.Value);
                        BuiltInParameterGroup paramGroup = (def.Key)?.ParameterGroup ?? BuiltInParameterGroup.INVALID;
                        targetDoc.ParameterBindings.Insert(def.Key, binding, paramGroup);
                trans.Commit();
            LogProjectParameters(projectParameterNames);
        private void LogProjectParameters(List<string> parameterNames)
            using (StreamWriter sw = new StreamWriter(logFilePath, true))
                foreach (var name in parameterNames)
                    sw.WriteLine(name);
Hope this will Helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
Message 3 of 10
Hans_Dwe
Thanks @Mohamed_Arshad for the answer, just by checking it, the part definition.ParameterType there is no definition for the Parametertype. any idea ?
Message 4 of 10
Mohamed_Arshad
Hi @Hans_Dwe
     To Create ExternalDefinition need to pass the Name and ParameterType in the Constructor, So I use the definition and pass its name and ParameterType to constructor for creating ExternalDefinition.
Mohamed Arshad K
Message 5 of 10
Hans_Dwe
@Mohamed_Arshad i am sorry i am not that deep into this before, this is what i meant, what should i do as next ?
Message 6 of 10
Mohamed_Arshad
@Hans_Dwe  Check the Below snippet
ExternalDefinitionCreationOptions creationOpt = new ExternalDefinitionCreationOptions(definition.Name, definition.GetDataType());
Mohamed Arshad K
Message 7 of 10
Mohamed_Arshad
Hi @Hans_Dwe
    I think you're using higher version of Revit so I have updated the code from 2021 to 2024, Kindly refer to the below code for Revit version 2024. Not too many changes only a few changes are there (Enum to Classes).
Updated Code:
using System;
using System.Linq;
using System.IO;
            iter.Reset();
                    targetDoc = doc;
                    break;
            #endregion
                trans.Start();
                foreach (KeyValuePair<ExternalDefinition, Definition> def in extDef)
                        ForgeTypeId paramGroup = (def.Key)?.GetGroupTypeId() ?? new ForgeTypeId(string.Empty);
                trans.Commit();
                    sw.WriteLine(name);
Mohamed Arshad K
Message 8 of 10
Hans_Dwe
@Mohamed_Arshad Yes you are right its 2024 version but unfortunately, i faced another error , i will look for it
Message 9 of 10
Mohamed_Arshad
HI @Hans_Dwe
  Sorry I made a small mistake in my Code, I'm trying to create the same group repeatedly so the error comes. Kindly check the below updated code.
Updated Code:
using System;
using System.Linq;
using System.IO;
using System.Dynamic;
            iter.Reset();
                    targetDoc = doc;
                    break;
            DefinitionFile definitionFile = uiapp.Application.OpenSharedParameterFile();
            DefinitionGroup definitionGroup = definitionFile.Groups.Create($"TemporaryDefintionGroup"); ;
            for (int i = 0; i < projectParameters.Count; i++)
                ExternalDefinitionCreationOptions creationOpt = new ExternalDefinitionCreationOptions(projectParameters[i].Name,
                    projectParameters[i].GetDataType());
                ///Create New Group for Identity Parameter Names
                if (definitionGroup.Definitions != null && definitionGroup.Definitions.Select(x => x.Name).Contains(projectParameters[i].Name))
                    DefinitionGroup temp = definitionFile.Groups.Create($"TemporaryDefintionGroup {i}");
                    extDef.Add(temp.Definitions.Create(creationOpt) as ExternalDefinition, projectParameters[i]);
                else
                    extDef.Add(definitionGroup.Definitions.Create(creationOpt) as ExternalDefinition, projectParameters[i]);
            #endregion
                trans.Start();
                        ForgeTypeId paramGroup = (def.Value)?.GetGroupTypeId() ?? new ForgeTypeId(string.Empty);
                trans.Commit();
                    sw.WriteLine(name);
Hope now it will work without error 🙂
Mohamed Arshad K
Message 10 of 10
Hans_Dwe
@Mohamed_Arshad perfect it worked like a charm. appreciate it 🙂
