Get definition of built-in parameter with-out having an element
SamBerk
SamBerk
Hi All
I want to get the StorageType UnitType and Parameter Type from built-in parameters when I don't have elements in my model that are using this parameter.
Is it possible to get the parameter definition of a built-in parameter with-out having an element in the model?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @SamBerk ,
try using the below link
built-in-parameter-name-and-labelutils.html
https://www.revitapidocs.com/2020/8cdbbb5c-a21e-ad1d-e9a3-6535f5d27894.htm
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
aignatovich
Hi!
It is simple to get a storage type of the parameter. Just use document.get_TypeOfStorage(BuiltInParameter...
Getting built-in parameter unit type is a bit more complicated. If you know the category parameter belongs to, you can create a view schedule in temporary transaction. You can find your parameter in schedule.Definition.GetSchedulableFields list:
var schedulableField = schedule
	.Definition
	.GetSchedulableFields()
	.Where(x => x.FieldType == ScheduleFieldType.Instance || x.FieldType == ScheduleFieldType.ElementType)
	.First(x => x.ParameterId == new ElementId(BuiltInParameter....));
Then add this schedulable field to the schedule, and get a schedule filed unit type:
schedule.Definition.AddField(schedulableField);
var unitType = schedule.Definition.GetField(0).UnitType;
This method works both for shared and built-in parameter.
SamBerk
Thanks @aignatovich for your help
But how can I know the ParamaterType for example Length, Number, Integer, Text, Area, Yes/No, etc?
floretti
I know this is an oldish post but I've been trying to get a built in parameter (elements' Phase Created) without having any elements in my project so I can setup some view filters and I managed to get at least their Ids via the below, which is a bit simpler. Note this currently works for 2024 and it may stop working in the future with API changes.
ForgeTypeId phaseCreatedTypeId = ParameterUtils.GetParameterTypeId(BuiltInParameter.PHASE_CREATED);
BuiltInParameter phaseCreatedBuiltInParam = ParameterUtils.GetBuiltInParameter(phaseCreatedTypeId);
ElementId phaseCreatedParamId = new ElementId(phaseCreatedBuiltInParam);
