Application Macros - change path location
lwlXUTTT
lwlXUTTT
Dear Community,
Is it possible to change the path of Application Macros in Revit?
Currently it is:
...\ProgramData\Autodesk\Revit\Macros\2022
and I would like to have it located on the server, not local disc.
Any hint, much appeciated,
Lukasz
sragan
I would say that’s probably not possible since that path is coded into the Revit program, and I don’t see any setting for that path in either the Revit settings, or in the Revit .ini file.
However, I think it should be possible to put a macro on the local machines that just calls and runs a macro file from the server.
im not sure exactly how to code that though.
